Old 04-11-2007, 06:26 AM
15yearsonptools 15yearsonptools is offline
Default Dear digi, please provide a list of all MIDI bugs
Please Digi,
Will you please post a list of MIDI bugs in 7.3.1
I am starting to loose my mind, I am experiencing a few "show stoppers" and I need to know that I don't have some weird MIDI anomaly.
PLEASE PLEASE..
Old 04-11-2007, 08:24 AM
Default Re: Dear digi, please provide a list of all MIDI bugs
USERS TOO!
Old 04-13-2007, 02:51 PM
sky88dd sky88dd is offline
I've noticed something from 7.3 and still happening in 7.3.1 cs2.
I have been able to duplicate this problem with both of my setups(G5 and MacBook Pro) using both a midi interface(midisport 4x4) or using the usb of my midi keyboard.
I have tried using M-audio Axiom 25 and also a no brand midi keyboard with the same results.
Whenever I try to record on an instrument track, I enable countoff.
While its counting off, sometimes I'll play something on the keyboard just to make sure I have my fingers on the right notes.
The data I just played during countoff gets recorded on the track as small "x" that you need to zoom in to see.
Of course, if you played something during the countoff and while its recording, then the data you played during countoff and the data you played when its actually recording will be overlapped.
I started noticing this when some notes tend to clip. That's when I found out that they are overlapped.
Then I tried to play something during the countoff but not playing during the actual recording.
Pressed stop and there they are, those little dots. And if you zoom in, you will see them as little "x"s.
I've called Digi since I got 7.3 and they told me to wait for the cs update.
As far as I know, cs2 didn't get that fixed.
Of course the workaround is to not play something during the countoff, but being such a bad keyboard player, sometimes I need to make sure I have my fingers where they're supposed to be.
Then I'd have to manually slide the notes to reveal the little "x"s and delete them.
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Old 04-26-2007, 09:46 AM
sircharles2 sircharles2 is offline
I have a few years experience with PT as well. I recently upgraded from 5.3.3 to 7.3.1 I've got a brand new machine: PC Intel Duo core2 Processor with 2Gs of ram. I'm also running a few virtual intruments too.
my Problem is that when ever I try to record midi using my Triton keyboard with midi sport 1x1 interface Pro Tools freezes.
I've updated every driver I can think of but the problem persist. Its not an immediate freeze, instead it usually happens about 10-15 minutes into sequencing. Just when I get in my groove, as I'm sequencing Protools freezes and the last note that was played will remain in play until I restart the PC.
I need some serious help. DIGI were R U?
SiSoftware Sandra
System
Host Name : USER-AD7A5AF8E9
User : Administrator
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
Speed : 2.13GHz
Performance Rating : PR7236 (estimated)
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size
L2 On-board Cache : 1x 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing
Mainboard
Bus(es) : ISA AGP PCI PCIe USB FireWire/1394
MP Support : 1 Processor(s)
MP APIC : No
System BIOS : American Megatrends Inc. 8.13
System : ECS PT890T-A
Mainboard : ECS PT890T-A
Total Memory : 2GB DDR2-SDRAM
Chipset 1
Chipset : VIA P4M890
Model : Elitegroup Computer Sys Standard Host Bridge
Front Side Bus Speed : 4x 266MHz (1064MHz data rate)
Total Memory : 1GB DDR2-SDRAM
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : RADEON X1600 Series
Adapter : RADEON X1600 Series Secondary
Physical Storage Devices
Hard Disk : WDC WD3200JS-22PDB0 (298GB)
Hard Disk : Apple iPod USB Device
Hard Disk : Memorex TD Classic 003C USB Device
CD-ROM/DVD : HP DVD Writer 940d (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
Logical Storage Devices
Hard Disk (C:) : 298GB (198GB, 66% Free Space) (NTFS)
CD-ROM/DVD (D:) : N/A
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller
USB Controller/Hub : VIA USB Enhanced Host Controller
USB Controller/Hub : USB Root Hub
USB Controller/Hub : USB Mass Storage Device
USB Controller/Hub : USB Composite Device
USB Controller/Hub : Generic USB Hub
FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Microsoft PS/2 Mouse
Printers and Faxes
Model : Microsoft Office Document Image Writer
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2)
Network Services
Adapter : VIA Rhine II Fast Ethernet Adapter
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.
Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings.
PT LE 7.3.1 M Box
Intel Q9550 4G DDR2
Akai MPK 49
Grand Rapids/Lansing/Detroit MI hiphop head
Old 04-26-2007, 09:55 AM
DigiTechSupt's Avatar
Processor
There's you're problem - you're running an incompatible processor/chipset combination. If you have an Intel processor, you must have an Intel chipset on the motherboard - yours has a VIA chipset.
Avid Audio Tech Support
Support FAQ
Old 09-24-2007, 08:42 AM
Recording midi on an instrument track
Punching in at the end of a bar (after the last midi note) PT whipes out the bar previuos to the punch.
Logic is looking better and better every day
Old 09-24-2007, 08:45 AM
more science on the above..
If I punch in before the downbeat (1st beat of the bar) The previous bar is whipped out.. after the downbeat and it's fine.
Dear digi, please provide a list of all MIDI bugs 15yearsonptools MIDI 0 04-11-2007 06:26 AM
6.9.2 list of bugs Mike Czech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-15-2005 07:04 PM
A list of those annoying bugs for DIGI audio junkie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-04-2002 04:13 AM
Could Digi post an official list of known bugs in 5.1? Stratman Pro Tools TDM Systems (Mac) 24 03-21-2001 07:01 AM
DIGI-Please Provide Us More Information NBH Pro Tools TDM Systems (Mac) 8 08-18-2000 10:03 AM
