I seem to be very limited in the amount of tracks I can playback
In my sessions I seem to get stuck at around like 15-20 tracks before I start getting the CPU overload message. This is just in playback not recording. Usually, my tracks only have like an EQ and compressor on them with an occasional more powerful plugin. I also have my H/W buffer size maxed at 1024. What do I need to do to maximize my tracks and use PT to it's full potential?
I am using a Macbook with OS X version 10.6(I know I need to update) and it has 4gb of RAM. Matt P.s. I have done all of Avid's recommended optimization stuff except turn off Blue Tooth because I use Macs blue tooth keyboard but I wasn't sure if that could really be that big of a problem. |
Check out this video
http://www.google.com/url?sa=t&sourc...OespdBEKchZzEw Sent from my SGH-T769 using Tapatalk 2 |
Re: I seem to be very limited in the amount of tracks I can playback
You haven't given us any info on which MacBook you are using. The type and power of the processor is key to the answer to your question.
If he's only getting 15-20 tracks it would have to be a Macbook from the 90's or something. Something's clearly set up wrong here.
But agreed there's something wrong here if indeed he's getting the problem on playback and not record, especially at a 1024 buffer. Looking at his equipment profile he's using a Zoom R24 as his I/O and his MB has 10.6.8 but no mention of exactly which MB he has. He's probably recording to and pulling audio from his internal system hard drive which is always a no-no, especially for any decent amount of tracks, not that 15-20 tracks should be a strain. |
Then again, his 15-20 tracks might all be stereo, which equates to 30-40 tracks of audio
Matt;
It would be easier for us to help you if you put your system specs in your signature, I found this from a previous post of the OP, have at 'r folks... "Computer model and processor speed: Macbook and 2ghz intel core 2 duo OS: Mac OS x version 10.6.8 Pro Tools 9 version 9.0.5. 4gb of RAM Attached directly to the computers USB ports I have my Zoom R24 interface and a 10-port USB hub, plugged into that I have a USB MIDI converter, my Ilok, my Alesis USB speakers, and occasionally a USB micro card reader and a 40 GB hard drive. I have unplugged all of this down to just the bare minimum to run pro tools and record (Zoom R24, and Ilok). I also have an external monitor plugged in via a converter. and 1 firewire disk drive and 1 firewire hard drive but like I said I have unplugged all of this and the problem persists so it is not in the connections." So I guess I have to ask, what drive are you recording to?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
What's confusing is when he says he has 1 firewire disk drive and 1 firewire hard drive. Those are both disk drives, right? I'm also thinking he's run out of bandwidth on either the FW or USB bus (or both). 40 gig hard drive on the USB bus? Do they even make drives that small anymore? |
PT9 Limited Playback of WMV | bwacs | Windows | 0 | 05-19-2011 10:26 AM |
Amount of MIDI tracks... | greenwall | Pro Tools TDM Systems (Mac) | 1 | 05-28-2010 02:35 PM |
playback limited to 16 tracks ??!! | majorlabel | Pro Tools M-Powered (Win) | 5 | 04-13-2006 11:31 PM |
? about amount of tracks | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-03-2003 01:55 PM |
DIGI 002 MAX amount of Rec tracks at once? | fourthtunz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 08-07-2002 12:45 AM |
