Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-18-2021, 04:03 PM
PeterScherr PeterScherr is offline
Default Clipboard Manager for PT?
Can anyone recommend a clipboard manager that works with pro tools?
I do a lot of audiobook work, and when formatting these projects, I am always rotating between pasting several standard length pieces of room tone. (eg 0.5",1.5", 2.0", 2.5", 0.75" etc.)
If I could store all of these in a multi-tiered clipboard and paste them with custom key strokes, that would save me heaps of time and effort.
Thanks!
Pete Scherr
Old 02-18-2021, 04:18 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Clipboard Manager for PT?
I don't think there is. But, you could name them as 001 0.5, 002 0.75, etc. They should then be top of the Clip List. Leave the Clip List open and just drag what you want to where you want - in Slip Mode.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-19-2021, 09:32 AM
Hey Bruce,
Thanks! Great minds think alike -nearly...
I've been working this way for many years, but at this phase of the work, I use shuffle mode exclusively. It might seem strange, but in the audio book world, it makes perfect sense...
In order to keep the pauses all visible in the bin, I add the suffix "pause" to each one. That saves a little time.
But the right clip manager would really be slick.
Pete
Old 02-20-2021, 08:15 AM
albee1952 albee1952 is online now
Don't forget that you can use muted audio tracks to hold clips(or Playlists, for that matter)
Old 02-20-2021, 09:00 AM
JingleDjango JingleDjango is offline
Originally Posted by PeterScherr View Post
Hey Bruce,
Pete
Pete, I've recorded many audiobooks for notable publishers but never done the edit (though I edit lots of VO for other formats). Can you recommend any resources on workflow and technique?
Old 02-20-2021, 09:42 AM
The Weed's Avatar
I think the Clip List is as close as you can get to a multi-tiered clipboard as a normal clipboard only holds one object at a time.
You could have one length the longest you'll need, copy in and trim back to fit - tedious.
You could just have room tone under everything - not ideal.
I'll add two ways to use Playlists to albee's suggestion:
1) Put each length of room tone on a separate Playlist below each audio track. You can even color code them to represent each length. Now duplicate each as many times as you think you will need and use the new separate by "x" amount to space them down the timeline. Now you can just drag to the place you want whatever length you need.
2) If you already have the gap you need in place, put the room tone on an audio track under the edited audio track you want the room tone on, the same length as that audio track. Put the Grid in Clips & Markers. Highlight both tracks and use Separate at Grid. Put the now separated room tone audio on a Playlist under the audio track and promote the length you need to the main track with the Up Arrow or keyboard shortcut.
SonoBus
Old 02-20-2021, 01:42 PM
Hi there,
I think specific workflows would be at least somewhat affected by a publisher's particular style sheet. I've honed my post workflow over many years for my company, and I'd be happy to share some info with you. DM me at my email addy, should be part of my profile.
Pete
Old 02-20-2021, 01:48 PM
(I'm not familiar with this feature... I'll check it out. I'm kind of an old dog old tricks guy
By the time that I get to the editing and formatting phase of a project, chapters are already separated at pause spots and correction splicce spots. The amount of existing tone in a chapter pre-edit is slightly different for each one, based on how the narrators read and punch in, so I'm not sure that this would work out. Anyway, maybe if I consider it for a while, I'll think of something. Many thanks for taking the time to write!
Old 02-23-2021, 06:55 PM
smurfyou smurfyou is offline
I accomplish this exact task with Keyboard Maestro. I create memory locations that are selections for each length of tone. Then I program a macro to copy the current timecode, go to that marker, copy, goto the copied timecode, paste. Works like a charm.
~Will
how do i empty the clipboard?? pkingduk Pro Tools TDM Systems (Mac) 8 01-29-2008 12:35 PM
7.2 Clipboard bug Farmer Dave Pro Tools TDM Systems (Mac) 7 09-13-2006 06:22 PM
Clipboard Chris Cavell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-07-2004 12:55 PM
Clipboard functionality in 6.2.2? Glenn G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-30-2003 03:46 PM
Clipboard bug JimC Pro Tools TDM Systems (Mac) 1 06-14-2003 05:56 AM
