#21
Re: Aae 9173
If booting to BIOS doesn't show options for C States, it might be in a bios sub-menu. Google for a solution, on your specific Dell model bios, or, ask Dell tech support. All the other optimizations you listed need to be addressed, too. Do them ALL and your rig should work!!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#22
Re: Aae 9173
Scroll down to Processor power management and expand it.
That isn't there. The options stop at "sleep". Now PT doesn't recognize my Waves plugins. It still randomly stalls and cancels the recording. What am I missing? |
#23
Re: Aae 9173
Is your WavesHell up to date? Always check for new version when you suspect plugin has any part of your problem
#24
Re: Aae 9173
I don't now. It's in Waves Central. I don't want to recover it if its already there somewhere. This has been a night mare. Things are getting worse. I am not messing in BIOS, especially when the direction aren't clear and specific. C state isn't there that I can find and everything I do compounds into another issue.
This seriously can't be this hard in 2021 to run basic Protools on a new laptop with 32 GB of RAM. I am missing something. |
#25
Re: Aae 9173
OP
Just trying to help, all suggestions IMHO... My guess is that PT is OK under light load on your Notebook, when load increases the clock speed ramps up (C State/Turbo switching) and then the cooling limits are violated on the CPU (because processing audio puts a sustained load on the CPU, unlike business applications for which Turbo Mode was invented), so it ramps the CPU down again (C State/Turbo switching) and that results is an error. I have found PT to be very sensitive to C State/Turbo mode switching. The state switch causes a temporary drop in CPU throughput which causes PT to throw the error - or a click/pop as the audio buffer empties. Increased buffer sizes should decrease the rate of errors to a point. On a Notebook it is very common not to be able to control C State/Turbo switching from BIOS. Maybe Dell has a utility ? Do you hear the fans ramp up before PT throws an error ? Does the bottom of the Notebook get hot ? Under very light load is it stable - say play one empty track. Here's a good one, do you get fewer errors if the Notebook is plugged into the wall ? Battery life control can also cause C State/Turbo switching. Maybe that helps. Dunno e |
#26
Re: Aae 9173
It's plugged into my Furman. Never battery.
I don't understand this BIOS/C state stuff. I downloaded some program that said it disabled Turbo Boost. Protool still just givers the plugin error on one track after about 20 seconds. Sometimes. It has gotten worse since I started all this. Could someone please point me to where a regular human can fix this? I type in C state disabled and it's just gibberish. |
#27
Re: Aae 9173
No it isn't, running basic PT is easy if you have supported platform. What is hard in 2021 is running multiple 3rd party plugins
#28
Re: Aae 9173
Anyway, I found C states and Turbo Boost in BIOS and deactivated them. We'll see. Last edited by JFreak; 02-10-2021 at 12:22 AM. Reason: fixed the quote |
#29
Re: Aae 9173
Nope. Still got the error and stop on the 2nd take of 1 mic/channel on a 3 minute song.
#30
Re: Aae 9173
Sayin' that Avid only tests Avid plugins, nothing more. So once you have strange problems standard troubleshooting is moving all plugins to unused folder (Avid stock plugins will be copied back on next PT launch) and see if the problem went away. Then start moving plugins back one vendor at a time and expect the problem come back at some point. Which is the point when you know which vendor plugins you need to update (or stop using).
Remember plugins are loaded into memory even if you do not use them in the session, which is why moving to unused folder is essential in troubleshooting. Even one bad plugin can make your system unstable.
9173, 9173, 9173... Hellooooo | Rectifried | Pro Tools 12 | 2 | 04-19-2018 12:50 AM |
Dae 9173 | danyg | Pro Tools 2018 | 6 | 04-17-2018 04:04 PM |
Aae -9173 | frcjt | Pro Tools 12 | 17 | 03-27-2016 08:09 PM |
PT 12 - When 9173 is not actually 9173? | taft_mashburn | Pro Tools 12 | 2 | 10-06-2015 09:28 PM |
Cpu 9173 | mistermackum | Pro Tools 11 | 1 | 12-20-2014 02:20 AM |
