Old 11-11-2021, 10:10 PM
Dizzi45Z Dizzi45Z is offline
Default Komplete Kontrol with an S3 in Pro Tools 2021.10
I am currently struggling with the S3 and Komplete Kontrol fighting with each other. It seems that there is no way to have the S3 function independently of the way that Komplete Kontrol wants to display the tracks.
The S3 would allow me to select tracks in Pro Tools that are not one of the 16 on the surface and the surface would not shift and change.
Komplete Kontrol seems to always want the tracks you select in Pro Tools to be part of the 8 tracks that show up in the mixer section and then forces that view to be the first 8 channels of the S3.
This is causing quite a few issues between the two. Because their behaviors are different, I would love to have them both working independent of each other. Is there any way to do that?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 11-18-2021, 08:09 AM
Default Re: Komplete Kontrol with an S3 in Pro Tools 2021.10
Does no one else have both a Komplete Kontrol and a Eucon device running at the same time?
160 GB RAM
macOS 11.7.4
Old 11-19-2021, 08:45 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Dizzi45Z
Could you start a case and provide a video for me? I'd like to get a closer look at this.
https://avid.secure.force.com/pkb/ar...-Case-Creation
mark
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 02-26-2022, 06:33 PM
Originally Posted by MCorbin View Post
Dizzi45Z
mark
I will fill out the form as well. But I just had enough time to create a somewhat in depth video of this issue. I will fill out the case later.
S3 and Komplete Kontrol Pro Tools 2021.12
160 GB RAM
macOS 11.7.4
Old 09-30-2022, 09:35 AM
I'm not sure where this got fixed. But I tried setting up my Komplete Kontrol today again with the S3 and I'm not having any of these issues.
Thank you to the Avid team for fixing this! I never thought this would get fixed.
I also appreciate the new options in preferences with 2022.9 that allow me to tell the edit and mix window not to follow selections from the controller.
Thank you!
160 GB RAM
macOS 11.7.4
Pro tools 2020 Komplete Kontrol DamienLefevre Pro Tools 2020 2 02-18-2021 06:37 AM
HELP! Pro Tools and Komplete Kontrol HarvSpek Pro Tools 2020 3 10-24-2020 09:04 AM
Pro tools & Komplete Kontrol Thuser Virtual Instruments 5 12-20-2017 02:46 PM
Pro Tools 12 with NI Komplete Kontrol randb1 AAX Plug-ins 7 05-27-2015 02:20 PM
Loading Komplete Kontrol in Pro Tools 11 LadyKane Virtual Instruments 12 05-22-2015 04:53 PM
