Computer Noise when using MBox and Digi Core Audio
Hi, I've just purchased an MBox with LE 6.7 when i use the Mbox as my audio outs within any application includine Pro Tools i have a high pitched computer noise coming through. I have reconnected my previous soundcard and this problem goes away so it is specifically with the Digi Core Audio manager as when i quit this it also disappears. I would be very grateful if someone could help me with this issue as i'm going insane trying to solve it. All conections have been swapped and checked. Thanks Add
I'm running a Dual 1.25GHz Power Mac G4 with 512 ram and MBox with LE6.7 |
Re: Computer Noise when using MBox and Digi Core Audio
Ummm... you might want to post this in the LE for MAC forum
Sometimes this can be cured by using a powered usb hub. If you are using a laptop try on battery and see if that helps. I had the same problem on my laptop but it was not very loud. It went away with either a powered hub but also a high quality usb cable helped (IXOF)
Good luck! |
White noise on first four channels of Digi 002R with Core Audio | Sunzate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 02-01-2013 11:48 PM |
mBox 2 and Core Audio Noise | Iain Graham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-08-2007 10:57 AM |
White Noise through Mbox using Core Audio | The Dougfather | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-16-2005 04:28 PM |
Computer Noise with Digi Core Audio Manager | Adam Peters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-25-2005 11:52 PM |
Mbox and Digi Core Audio driver causing freezes | Matthew Cochrane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-25-2004 08:54 PM |
