Old 09-28-2015, 12:37 PM
ArtyMorty ArtyMorty is offline
Default HDX Input Monitoring level changes to previous fader level when disengaged
I have a question regarding Input Monitoring on HDX.
If I engage "input" monitoring on a track then change its fader level and press play, the fader does not move. Good.
However, if I disengage input monitoring then press play the fader jumps back to its previous value from before engaging input monitoring.
This does not occur when I have REC engaged but does when I have REC and Input engaged then disengage Input.
I find this annoying as I'd like the fader to stay at the level I choose When "I" is disengaged.
I can't seem to find any settings that let me change this behavior so I was wondering if this has always been the case with Pro Tools and I just don't remember.
Can anyone confirm this is normal or should I trash prefs?
"Link Record and Play Faders" is checked.
Thanks.
Pro Tools 12.2
OSX 10.10.5
HDX/Omni
Mac Pro 5,1 - 6 core
32g RAM
SSD HD - sys
Ext. HD - PT
Old 09-28-2015, 10:57 PM
Stig Eliassen's Avatar
Default Re: HDX Input Monitoring level changes to previous fader level when disengaged
I believe it's always been like this, but not sure.
Anyway, go to Setup (menu) > Preferences > Operations tab > Record section > turn on Enable automation in record.
Old 09-29-2015, 08:27 AM
Thank you very much. This solved it for me.
I wonder if this option might have been automatically enabled in previous versions and I just took it for granted.
Have a great day.
Old 09-29-2015, 08:56 AM
Glad it worked for you.
This feature came with PT 11.
Old 09-29-2015, 09:21 AM
Ok that explains my confusion then. I went from PT10 to PT12.
input monitoring level and record level different Jason1 macOS 8 12-07-2014 10:06 AM
Record monitoring level different from Playback monitoring level. sonicflwr macOS 1 03-09-2012 10:05 AM
Mixer fader and input level Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-23-2010 07:43 PM
Input level monitoring Sir Bergersworth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-19-2006 08:01 PM
level meter freeze while monitoring input? artguilljr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-04-2000 03:52 PM
