Academic 7.3.1 will not recognize BFD
Song file opened; trying to use BFD within ProTools Academic; cannot find BFD in any pulldown menus; nor in any inserts or output; nowhere to be found??
thanks in advance ron |
Re: Academic 7.3.1 will not recognize BFD
Which version of BFD specifically? The full version, or the demo? (the demo is not RTAS compatible).
Was it installed before you installed Pro Tools? If so, you might need to re-install BFD.
"premium acoustic drum module v 1.5" NOT a demo.
Have reinstalled BFD 3 times (with PTools already up and running) to no avail. Thanks for your help. By the way........I can use BFD alone just fine..........it's when I open PT that it's nowhere to be found. When I click on "output" in mixer channel........the only thing listed "microsoft midimapper". I think this is where BFD should be found? Have tried Midi channels, audio channels, instrument channels. |
not showing up as a plug-in insert. I believe it should be coming up in "Insert" "Other"...but...it's not in any of the insert listings.
no........it was not literally running.....I should have said installed
BFD should actually show up in the "Instrument" category on the insert list.
When you run the BFD installer, are you making sure to select the BFD RTAS version during the install process? (hint: you need to be) Here's a photo example: BFD Install selections If your BFD install does not include that option or that window, then you do not have the proper version of BFD.
SETUP HAS 2 CHOICES
RTAS FOR PT 6 RTAS FOR PT7 (WHICH IS WHAT I'M CLICKING ON) |
The menu that lists "rta for pt7" is the same setup menu that is in the photo you mentioned. There are 2 choices for RTA......PTools 6 and PTools 7. This is on the original, registered setup install disk.
Help! Pro Tools Academic 7.3 Wont Recognize my 002 rack | 4164 | Pro Tools M-Powered (Mac) | 1 | 10-24-2012 07:09 PM |
PTE Academic (or any PT Academic versions) | DrmnWmn58 | Pro Tools Express on Mac OS X | 2 | 05-02-2012 02:20 PM |
PTMP 8 academic to PT9 academic | trymonlam | Pro Tools 9 | 0 | 04-19-2012 01:39 AM |
Audio/midi setup doesn't recognize my mbox 2 academic? | jpp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2009 10:49 PM |
M-Powered Academic 7.4 / M-Audio MobilePre USB Academic Error Message | JustparaDOX | Pro Tools M-Powered (Win) | 1 | 10-31-2008 10:09 AM |
