changing tempo doesn't align to the grid
I have an issue when i set a tempo change in the midi editing window, it doesn't align properly to the grid even if I set or select the first beat of a bar, in grid mode. The workaround I found is to set up the tempo change in the edit window, it aligns correctly in this case both on edit AND midi editing window. Am I doing something wrong or is it a known bug ? Thanks for you reply ! ----------------------------------- Pro tools 2018.12 - Win 10 x64 |
When changing tempo - the grid do "jump" some bars | senghor | Pro Tools 2018 | 5 | 09-19-2018 12:05 PM |
Move regions with grid while changing tempo | rolybarabas | macOS | 2 | 01-17-2015 10:39 AM |
Lock to grid when changing tempo? | goka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-29-2003 08:42 PM |
Can align grid to different tempo after recording MIDI? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-28-2001 08:28 AM |
Tempo change and grid doesn't match | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-19-2001 11:56 AM |
