Old 03-25-2014, 07:12 PM
outoftune outoftune is offline
Default how to get 4 x hardware inserts with AVID OMNI / PT HD
I have an Avid HD OMNI and PT Native Thunderbolt card.
I'm trying to set it up so I can use 4 x hardware inserts on the OMNI but because of the "stereo monitor" path it doesn't seem to let me.
has anyone been able to get this to work? is it possible?
i am trying to set it up but it won't let me change where the MONITOR is assigned.
Old 03-25-2014, 10:47 PM
Craig F Craig F is offline
Default Re: how to get 4 x hardware inserts with AVID OMNI / PT HD
Inserts have to be match pairs so if all your inserts need to be analog you'll need an DA/AD pair to use an AES I/O pair
But I don't have any Omni experience so I don't know
Thank you,
Craig
Old 03-27-2014, 06:36 PM
is there any way to unlock the "stereo monitor" from being the output 1-2.
even when i change it to 7-8 in the monitor panel, it still won't let me change 1-2.
Old 03-30-2014, 11:22 AM
Mike496's Avatar
Mike496 Mike496 is offline
This still bums me out
Old 03-30-2014, 12:23 PM
albee1952 albee1952 is online now
I sure wish Avid had either limited the OMNI more(so fewer would buy it and be disappointed) or allow it to do 16 IO total. The HD 8x8x8 IO and a monitor controller is a much better option for far too many users
Old 03-31-2014, 04:10 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
You should be able to disable the monitor in the Monitor Tab section. That will give you 8 analogue outs and 4 ins.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 03-31-2014, 08:07 AM
nst7 nst7 is offline
Outoftune,
Here is the old thread I mentioned that I would try to find:
http://duc.avid.com/showthread.php?t...ht=omni+insert
On the second page, Psychomonkey found the solution, which I'll copy here:
"worked it out eventually!
For anyone else still struggling, you have to have:
Monitor Path on 7-8 (or 5/6, but I'm using the TRS mirror so can't do it on 5/6), under Hardware Setup - Monitor Tab.
CRUCIAL POINT I WAS MISSING:
Under Hardware Setup - Main tab, you HAVE to have a path other than 1-2 assigned to physical outputs 1-2. In my case, I'm using path 5-6 with physical IO 1-2.
This is the confusing part! With the OMNI, you can have physical IO routed so PT sees it differently, but the Monitor path is fixed to 1-2.
Oh, and it helps to have 1/2 set to "line" on the front of the OMNI...that foxed me for a bit!
Hope that helps anyone else struggling!"
This relates to what I was mentioning in another thread you posted (maybe on Gearslutz), in which I mentioned that Monitor 1-2 is just a designation that does not always correspond to output 1-2.
Old 04-04-2014, 08:53 AM
hi everyone, thank you for the input i'm going to try this.
Using a Distressor as a hardware insert with Avid Omni & ProTools 11 HDX agrizzlybear Third Party Interfaces 8 03-20-2014 12:10 PM
Hardware insert 1&2 cutting off other hardware inserts on aux tracks Led Windows 4 12-09-2013 09:19 AM
OMNI inserts only for mic pre , or used as master buss inserts as well Weird Audio Pro Tools TDM Systems (Mac) 3 11-14-2012 09:27 PM
Compressor with Omni - Inserts or Patchbay? Cliffy_Boy Pro Tools TDM Systems (Mac) 6 11-28-2011 11:09 AM
OMNI physical I/O question (inserts) Picture Start Pro Tools TDM Systems (Mac) 4 11-03-2011 12:41 PM
