Old 01-07-2010, 04:17 PM
Rythameen Rythameen is offline
Default Getting Pro Tools to run on HP i7 laptop
I have a new hp i7 laptop with Windows 7 64 bit, M-Box 2 Pro firewire and PT 8.03. Got everything installed correctly, followed the guidlines for setting up windows for pro tools. I am hooking the m-box up to the internal 4 pin firewire port, and using a SIIG firewire card in the express card port for the audio drive.
I fired up PT and loaded a session with 48 tracks, hardly any plugs and it played back great a couple of times, then I got the dreaded notice that the cpu was busy and I should lower the buffer setting, so I lowered it from 1024 to 512, and instantly PT said I should raise the buffer setting. I go thorugh this for about 10 minutes, and then it plays great, but then out of the blue, I'm back to the notices.System usage meter says that I am using about 10% of the CPU (RTAS) and disk usage is about 25%. I have tried plugging the M-Box into the SIGG card, and the drive into the internal 4 pin, but it doesn't seem to make any difference. TIA for any help.............sandra below
SiSoftware Sandra
Computer
Model : HP HP Pavilion dv7 Notebook PC
Workgroup : WORKGROUP
Host Name : CliffConradi-PC
User : Cliff Conradi
Processor
Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
Speed : 1.73GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Quanta 363C
BIOS : HP F.04 09/10/2009
Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 6GB DDR3 SO-DIMM
Chipset
Model : HP Clarksfield/Lynnfield DMI
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : HP Core Mobile (Clarksfield) UnCore
Front Side Bus Speed : 2x 2.13GHz (4.26GHz)
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Samsung M471B5673EH1-CH9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Samsung M471B5273BH1-CF8 4GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4)
Video System
Video Adapter : NVIDIA GeForce GT 230M (32 SM4.1, 1GB DDR3, PCIe 2.00 x16)
Graphics Processor
Storage Devices
ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (D:)
SAMSUNG HD501LJ (500.1GB, FireWire/1394, 3.5", 7200rpm, NCQ, 8MB Cache) : 466GB (G:)
hp DVDRAM GT20L (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (E:)
Logical Storage Devices
SYSTEM : 199MB (NTFS)
New Volume (G:) : 466GB (NTFS) @ SAMSUNG HD501LJ (500.1GB, FireWire/1394, 3.5", 7200rpm, NCQ, 8MB Cache)
Hard Disk (C:) : 450GB (NTFS) @ ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache)
RECOVERY (D:) : 15GB (NTFS) @ ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache)
HP_TOOLS : 99MB (FAT32)
Optical Drive (E:) : N/A @ hp DVDRAM GT20L (SATA150, DVD+-RW, CD-RW, 1MB Cache)
Peripherals
LPC Hub Controller 1 : HP P55/PM55/3400 LPC Interface Controller
Audio Device : HP P55/PM55/3400 High Definition Audio
Audio Codec : Integrated Device Tech 7603h
Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem
Audio Device : HP High Definition Audio Controller
Audio Codec : nVidia 000Ah
Serial Port(s) : 1
Disk Controller : HP P55/PM55/3400 6 port SATA AHCI Controller
USB Controller 1 : HP P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : HP P55/PM55/3400 USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : HP IEEE 1394 Host Controller
FireWire/1394 Controller 2 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link)
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 01-07-2010, 04:24 PM
sw rec sw rec is online now
Default Re: Getting Pro Tools to run on HP i7 laptop
It might work better to daisy-chain the Mbox 2 Pro and the hard drive. And I'm trying to remember the path, someone correct me if this is wrong....is it PC>hard drive>interface?
This way you run them both off the approved FW controller.
Old 01-07-2010, 04:56 PM
I didn't think of trying that, I thought I remembered seeing somewhere on digi's site that the interface should be hooked to the internal firewire, and the drive to the SIIG. Another option I have is running the interface off the SIIG card and using the eSata port for the audio drive. Before I run out and buy the drive, do you think that an eSata drive would be okay with PT? Want to make sure before I tell the wife I need just one more drive.
Old 01-07-2010, 05:04 PM
AirborneFO AirborneFO is offline
I have found if you take the wife to Zales, you can pretty much finish out whatever you need for your system.......
iMac i5, Pro Tools 10.2, DIGI003 Command, Akai MPK49, Simmons SDK9
AKA: HoFo
"Yes, recording to the system drive is 99% likely THE main problem." sw rec
Old 01-07-2010, 05:07 PM
E sata is probably going to be the best way to do this, yes!
That's just funny, there, Airborne!!!!
Old 01-07-2010, 05:14 PM
Then Zales first, and eSata second it is.
Old 01-07-2010, 05:27 PM
LMAO! Got me a new computer build and a 500GB drive ta boot.
I've been married 16 years. Pride went out the window a LONG time ago........
AKA: HoFo
Old 01-07-2010, 08:47 PM
Been married 26 years myself....................could you explain that thing you mentioned, I think you called it pride?
Old 01-07-2010, 08:53 PM
Nope, can't be explained. I Googled it, but can only expect so much from that search engine...
I prefer to call it "negotiations"
She calls it pre-approved credit.
It's a win-win for both......
AKA: HoFo
Old 01-07-2010, 09:12 PM
Was just joking about the pride thing...............I left mine by the wayside a long time ago too. And with 26 years of marriage I am also well versed in the fine art of negotiation Or as my wife likes to call it "Oh go ahead and get it you big baby"!
What's the best Mac laptop to run Pro Tools 10.3 on? [email protected] Pro Tools 10 2 12-13-2013 11:51 PM
Laptop PC for Pro Tools 10 Mikolaj1022 Windows 9 06-15-2012 03:13 AM
Using My 002 With Pro Tools HD 10 Laptop??? Jay Terrien Windows 11 06-10-2012 08:20 PM
Will my new laptop run Pro Tools 9??? blankguitar Windows 1 03-13-2012 03:57 PM
Pro Tools LE 5.1.1 on laptop? Brady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-08-2002 05:53 AM
