Old 03-12-2006, 05:16 PM
Produce_Dept Produce_Dept is offline
Default Selection goes away when playback is stopped
Hey - I have a quick question... When I make a selection for editing with the selector tool, play it, and press stop - the selection goes away.
Is there a way to make a selection, press play, and then when I stop playback, have the selection still intact?
Thanks... Maybe if I RTFM I will figure it out.
-Kurt
Kurt Bullock
PT 7.4 HD2Accel Digi ProControl
G5 Dual 2.7 3.5gig RAM OS10.4.8
www.zeropointrecording.com
Old 03-12-2006, 05:30 PM
minister's Avatar
minister minister is offline
Default Re: Selection goes away when playback is stopped
do you have "Timeline Insertion Follows Playback" selected in the prefs? if so, toggle it off and see if that doeans't fix it.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 03-12-2006, 06:58 PM
Oops - yeah... I guess that I didnt see the correlation between having that on and my problem
Thanks for the help
Kurt Bullock
Old 03-12-2006, 07:10 PM
dawkab dawkab is offline
if you are in command focus mode on the edit window, pressing 'n' will
toggle this preference. Easy to hit by accident.
How to punch a selection but start playback before the selection... shotgunndunn macOS 1 01-19-2012 04:45 PM
Play/Edit Marker stopped following the timeline selection stern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2007 11:50 PM
Play/Edit Marker stopped follow timeline selection stern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-22-2007 11:30 PM
Selection Clears when Playback is Stopped tikboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-19-2006 09:25 PM
Losing selection when stopped Jeff Jewett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-10-2002 06:13 PM
