Old 09-06-2019, 12:23 PM
Default Track presets and mute/solo remembering?
Is it possible for a track preset to remember a track's solo or mute status? I don't see that as an option in the 'what to recall' window. Or am I missing something? I'm setting up some presets where it would be nice if I could have the preset come up with a certain configuration as to solo/mute. Particularly solo safe.
Something I noticed when saving a preset that I previously worked on using the same name it doesn't ask if I want to overwrite the existing preset or not.
Old 09-06-2019, 12:42 PM
Default Re: Track presets and mute/solo remembering?
I have no idea, but why not open that template file (rename to .ptx) and make the changes, save, rename back, and try if it works?
Old 09-06-2019, 12:44 PM
henningaround henningaround is offline
Concerning solo safe it definitely does work.
Old 09-06-2019, 01:34 PM
It's not a template but a track preset which has a different suffix. Or are you saying to make the changes to the preset, save it as a template (.ptxt) and then change the suffix back from .ptxt to the track preset suffix?
Thanks. I may have missed something.
Old 09-06-2019, 01:38 PM
That's what he meant, yes. You can just save any session as a track preset by changing the suffix and moving it to the track preset folder.
Old 09-06-2019, 01:56 PM
That's right. PT track preset is a session file that has .ptxp suffix. If found from right place it is nicely integrated to the system.
You should be able to freely edit the presets by renaming the suffix to .ptx and back to .ptxp again
Is there a CC/MIDI learn for track solo and mute? Sir Hannes Getting Started 1 04-13-2018 02:15 PM
Track Solo and Mute Not Highlighting seanmccoy macOS 4 09-25-2017 08:41 AM
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 02:59 PM
Why would one track not mute when another is in Solo Brad Gillie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2007 03:44 PM
Solo/Track Mute Problem JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2003 09:19 AM
