re: heat [solved]
Why is heat not showing in PT 11.0? Not even the little dock where it's suppose to be in the lower right corner of the mix window,or in the preferences under processing.
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Re: heat
Heat is AAX DSP only and requires the HDX core cards.
Re: heat
Of course, I responded before reading your signature block.
Looks like you have HDX cards installed. I thought you were running PT11 and not 11HD. |
Re: heat
Thanks
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
bought heat how to install [solved] | Filmusic | Pro Tools TDM Systems (Win) | 7 | 02-09-2013 07:43 AM |
re heat on 10 | 2224 | macOS | 9 | 08-12-2012 05:11 PM |
Heat | midnightsun | Pro Tools TDM Systems (Mac) | 2 | 03-09-2011 01:52 AM |
SOLVED>>Need HELP, SUPER ASAP.< |
audioindo | Pro Tools TDM Systems (Mac) | 18 | 04-21-2007 05:43 AM |
