Display bug or trouble with my system? Digi Tech Help?
Already, so I'm a little late installing 5.3.1, but I just got my new system up and running with my PT le and my Waves Gold bundle and now I have a concern with what I'm seeing...
Whenever I drag any item (transport, memory location list, big counter, etc) across another item such as the edit window or the mix window, while I leave my finger down on the left button of the mouse it drags a column of white across my screen that erases everything until I release the button. I'm not terribly concerned because the screen will correct itself when I do release the mouse, but I know this did not happen with my previous version of le, v 5.1.1, nor does it happen with my HD set-up at work. In my previous experience, little bugs like this have always pointed to larger problems... Should I be concerned or is this normal behavior for 5.3.1? Thank you for your assistance, Sean |
Re: Display bug or trouble with my system? Digi Tech Help?
Actually, this is a well known and completely harmless bug with ALL Windows versions of Pro Tools. It occurs on any Windows system in which "show window contents while dragging" is enabled.
You can either live with it like I do, or set Windows to NOT "show window contents while dragging," which is obviously how your other PT machines have been set in the past. Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
Cool...
I'm assuming I can turn that off in the Control Panel somewhere, but I couldn't find where... ? Care to give me a push in the right direction? Thanks for your help, Sean |
Right-click your desktop. Choose Properties. Choose the Appearance tab. Choose the Effects button.
Thanks, QuikDraw... I appreciate your help!
Sean |
Avid Tech Support: Trouble downloading additional content for PT9 | ilovemyssl | macOS | 4 | 03-07-2012 05:03 PM |
trouble with grid display | Jperkins | Pro Tools 9 | 2 | 04-14-2011 09:48 AM |
Digi Tech Sup: Color Display & Aux Send Display bugs | nob turner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-07-2010 02:43 PM |
Tech support...No Help! Channel Bar Display Freaks out. | McMasters | ICON & C|24 | 2 | 08-10-2003 04:15 PM |
tech suppt pleeze-motor mix trouble | thumbolt68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2000 05:03 PM |
