Old 04-12-2012, 05:54 AM
xy44 xy44 is offline
Default New ProTools Patch removed Speaker Breakup
As the title says..
This effected anyone else?
on my system after installed the patch, speaker breakup no longer exists!
Old 04-12-2012, 06:15 AM
Default Re: New ProTools Patch removed Speaker Breakup
Bet it removed a few other things as well you have not noticed! Need to run the erxp installer again.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 04-13-2012, 06:50 PM
sorcerer27 sorcerer27 is offline
Same thing happened here after installing the 10.1.2 update. Seems it screws up the graphic for the Speaker Breakup, and causes the slide adjustment to disappear! However, a reinstall of the Expansion Pack fixes it.
Old 04-15-2012, 02:07 PM
moff moff is offline
As has been said many times before, during the process of upgrading or updating ProTools, certain components required by the 11R, especially the ERXP, get overwritten. So after upgrading or updating Protools, you have to run the first half of the ERXP installer, to reinstall the required components into ProTools.
Old 04-15-2012, 09:35 PM
you can also just copy all the ui files out of the plugins folder for the eleven rack and store them on a flash drive or something and when you reinstall pt or update, just copy them back into your plugins folder and that will take care of it as well.
pro-tools-pc.com
Intel I7 9900k
Win 10
Speaker Breakup Chris Townsend Eleven Rack 23 04-26-2011 04:28 PM
Random Speaker Breakup? bredo Eleven Rack 4 03-27-2011 09:19 AM
Audio breakup diring playback cvw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-21-2007 02:25 PM
Digital Breakup and H/W Buffer Overrun all the time... Tony J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-03-2003 11:37 AM
timecode breakup not stopping online record. brahms Post - Surround - Video 3 02-18-2003 09:30 AM
