Insert Select Focuses Plugin
My normal workflow:
I use a URS channelstrip pro on the first insert of every channel. When starting a mix I usually: 1. Set all faders to unity gain 2. make sure no custom fader modes are active. 3. while holding "do to all" push the "inserts" button on a channel strip which shows the URS csp as the first insert across all channels. 4. while holding "do to all" push "select" below the scribble strip that displays URS. 5. At this point I used to see the "input gain" (of the plugin) for all channels across the lower rotary encoders. I would use this like a trim control on a console to set my rough levels for all tracks. Today I went to do this and instead of it working the way it used to, step3 focuses the plugin for one channel, displaying all its parameters across the rotaries. I would expect this when I actually press the "plugin" button on the focus channel section, but I'm not doing this. How do I get it to stop focusing the plugin and instead just display a single parameter for all channels at once? This is hard to explain without showing. Thanks, -Zak |
Re: Insert select on D-command - what's changed?
OK...more info...my initial post was while working on a 7.4 session. I just rebooted to my leopard/PT8 drive and it's working as it used to. When looking through my console pref's operations softkeys, I just noticed that there is no chanPI option in the 7.4 prefs but it is there when I'm using PT8.
Obviously there are some differences here. Is it firmware or does this behavior just change between 7.4 and 8? Thanks, |
It's not in the firmware. It's in the D Command personality file. It's installed with the software and becomes 'active' when you declare your controller. The difference you're seeing would indeed be added functionality for D Command in Pro Tools 8 Chris
Chris Lambrechts Applications Specialist- Live Sound |
-Z- |
Plugin window follow select? | jasenj1 | ICON & C|24 | 2 | 10-08-2014 07:39 AM |
How do you select a preset for a plugin? | Mike Landolt | ProControl, Control|24, Command|8 | 4 | 01-09-2008 07:46 PM |
Ikey: auto select an audiosuite plugin | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 04-19-2007 03:54 AM |
Select Plugin on the 002 and C8 | LuisB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-20-2005 11:22 AM |
Is there an easier way to select patches within the TDM Virus plugin via the keyboard | Fucius | General Discussion | 2 | 04-16-2001 09:31 PM |
