Old 01-30-2008, 03:33 PM
Joe_Foss Joe_Foss is offline
Default Using a LAPTOP with Pro Tools 7.4
Hello, I am in the process of setting up my little at home studio, but I'm starting to see some issues and I'm wondering if for some reason, my laptop is the problem. Is anyone out there having success with a laptop and Pro Tools? I am recording my PT files to an external USB drive, and I am using BFD2 which is on an external USB HD, but I keep using all these USB ports, instead of a PCI card for a desktop. Could it be that laptops just can't handle as much as a standard desktop PC?
I have 2 gigs of RAM, M-Audio Mobile Preamp, Dell Inspiron 1501 laptop, external USB HDs at 7200 RPM.
I'm just experiencing CPU overload in PT when I don't have that many tracks going, BFD latency with edrum kit, etc.
So I'm just wondering, could my laptop be a weak spot or should I look elsewhere to solve my problems?
Thanks!
don
Old 02-01-2008, 11:55 AM
JrummerJ JrummerJ is offline
Default Re: Using a LAPTOP with Pro Tools 7.4
Thanks!
don
First thing that people will point out is that USB drives are not recommended in any way. You probably want to use a firewire drive that has a certified Oxford chipset and if you don't have a fw port then add one by getting an expansion card.
Does BFD2 use disk streaming? If those samples are trying to play from a USB drive, I would say you haven't got a chance at low latency. If they are loading in RAM then you may just need to lower your buffer settings to reduce latency. Of course, lowering buffer won't help if you are getting the cpu overload errors.
It might help to know what OS you are on. Do you have the latest M-Audio drivers?
One thing to try is to ditch the external HDs and try recording/mixing from a session on the internal drive. This might tell you whether the external drive is causing the issue. You don't want to do this as a long term solution though, since recording on the internal drive isn't a good idea in general.
J
Old 02-01-2008, 12:27 PM
TheHenchman TheHenchman is offline
What kind of processor?
I use USB drives all the time, no problem at all.
I had nothign but problems trying to use the firewire port on my Dell, and sent it back, and bought an HP NC8430.
Zero problems, works great.
www.markhensley.tv
IMDB Credits
Old 02-02-2008, 08:42 AM
JazzyJ JazzyJ is offline
BFD is the most power hungry plugin that has ever been made. My mate with a G5 struggles with it.
Firewire is recommended, but it's not going to solve the BFD problem.
Your options are buy a faster laptop, which probably means MAC
or
Forget BFD and use EZDrummer which is very similar or maybe Addictive drums.
I can run 3 instances of easy drummer (2x latin perc and 1x Vintage kit) easily with other things going as well, on a
Dell Inspiron 6000,
1.73Ghz Intel,
2GB Ram, Win XP Home SP2,
EX Firewire or USB 7,200 Drive,
Mbox2 or Jamlab.
I also have a dual 1.3Ghz (2MB L3 Cache) G4 and can barely run BFD on that.
Seriously, I think that the idea of BFD is great but practically speaking - it's impractical.
Change your RTAS Drum synth and you will have solved your problem.
I've actually had this out with FXpansion 18 months ago and the came back with a crock of ****.
Anyway, this isn't advice, it's a fact. BFD is the most draining RTAS plugin on the face of the earth as we speak. We will need 10Ghz processors in laptops before we can even think about using it.
CPU has nothing to do with Streaming Disk stuff.
Hope that helps you see the light
JazzyJ
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Laptop PC for Pro Tools 10 Mikolaj1022 Windows 9 06-15-2012 03:13 AM
Using My 002 With Pro Tools HD 10 Laptop??? Jay Terrien Windows 11 06-10-2012 08:20 PM
Will my new laptop run Pro Tools 9??? blankguitar Windows 1 03-13-2012 03:57 PM
Getting Pro Tools to run on HP i7 laptop Rythameen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-19-2010 12:29 PM
Pro Tools LE 5.1.1 on laptop? Brady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-08-2002 05:53 AM
