#91
Re: How's 12.4 running for you?
For a 2009 computer, Mountain Lion will perform better than Mave**** or Yose****...
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
#92
My iMac on 10.9 has trouble with PT 12.4 when I have the audio running and I am making fine adjustments...I can crash it every time so I really have to be careful. Any adjustment from track volume, plug in changes, bus adjustments. This is my only problem.
Sam |
#93
Nice Guitar work, "I'll say my goodbyes"
#94
Update (This thread made me dig a bit deeper, thank you all)
Mac-Sapphire HD-7950 with 3 monitors OS 10.10.5 PT's HD10.4 I switched Video monitor cables to 1 DVI, 1 HDMI (Main), 1 Mini Display Port (Dual-link adaptor) My stuttering graphic issues have left the building. Previously using 2 Mini display ports and DVI with same setup = Graphic stutter.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#95
2011 iMac i5 2.7Ghz 12GB RAM OS 10.9.5
No tracking yet. I'm in mix mode big time this month. Don't use VI's other than occasional EZ Drummer. Plugins from Waves, Slate, AVID, Eventide, IK, Brainworx Celemony & Antares. Everything's working well. No issues. Maybe one crash over the last week or so of work. Commit and Freeze seem to work well. Big time savers, and I'm just scratching the surface with the current project. Amazed AVID was able to get by for as many years as they did while all the other DAW's implemented this workflow! I work a lot on HD outside the home studio, so the biggest thing for me is Disc Cache. That's helped me performance wise as well as anything that's been added. I'm getting a lot of mileage out of VCA's too Sorry for all those with the graphic issues. If you can get past that, this could be a fantastic upgrade.... Cheers,
JP |
#96
My first attempt to freeze tracks wasn't great. I hit freeze up the first insert (Reel Tape Saturation) on some drum tracks, it worked, PT didn't crash, but instead of sticking to the length of the regions in the tracks it rendered frozen regions longer than the originals and in random durations. A few much longer, most just a bit longer.
Pro Tools 12.4 HD Native, OS 10.8.5 |
#97
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#98
I just attempted an OMF import in 12.4 and after it got through the first track it decided to stop copying audio files into the session. Figured I'd close and reopen the session to see if it would make another attempt at finding the audio in the OMF, and as I looked at the Task Manager, sure enough, it started bringing in more audio. However, this new audio all had some kind of constant waveform graphic and complete silence for audio.
Not good. At that point I decided to blow away everything Pro Tools had imported from the OMF and try importing session data from scratch. This time, it didn't even get as far as it did the time before. On the initial progress bar for when it's gathering audio files (the one in the dialog box), Pro Tools stopped responding and gave me the beachball of death. I'll try this at work tomorrow on a PT10 system just to see if it's possibly a bad OMF, but it didn't look bad. |
#99
I'm running 12.4 on an ancient 3,1 mac pro. The freeze tracks has so far worked perfect. FWIW I'm still on mountain lion. I have yosemite and el crapitan but ML just works and I'm thinking all those goofy extra "features" the newer OS's have just slow down and overcomplicate
For some one with limited horsepower 12.4 has been a huge game changer: Create powerful tracks, freeze em and move on
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers |
#100
Back with the RTS, I actually did the opposite on another test and increased the noise to the highest level and it not only gave me a short burst right after finishing the rendering process, but also rendered about 1 minute of pure noise after the original regions had ended. A few details though: if I hit Cmd+A to select the whole region (original length+1min) it only selects the original length. If I use the Grabber tool though it considers the longer frozen region (as well as using tab to region). And this time the frozen regions weren't randomly stretched, they all had the same length. But the noise did start with a delay inside the resulting frozen regions, with one region (out of 7) starting at a different time. ADC was ON. With ADC OFF there was no delay between frozen regions. |
Dual Boot 10.6 running 8HD & 10.7 running 10HD | STL Audio | macOS | 3 | 04-14-2012 05:38 AM |
Im running PT8 on WIN7(running off of VMWARE) | Conolly10 | Windows | 2 | 12-11-2010 06:38 PM |
PT HD9 (running native with motu) running out of memory | syMPh | Pro Tools TDM Systems (Mac) | 1 | 11-21-2010 07:34 PM |
Running Pro Tools LE 8 on XP and running 2 monitors | JRup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 05-31-2010 07:38 PM |
Running PTLE for Win on an Intel Mac running XP? | postmike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-27-2006 11:08 AM |
