Old 02-22-2017, 07:56 AM
larsongs larsongs is offline
Default Vocal Compression ???
Is there any advantage when recording Vocals or Instruments to run Mic to Compressor to Pre Amp to Interface? Or is it better to run Mic to Pre Amp to Compressor to Interface?
Advantages or disadvantages?
Thanks
Old 02-22-2017, 08:12 AM
zoff zoff is offline
Default Re: Vocal Compression ???
Thanks
You can't run mic to compressor because the compressor will need a line level signal.
macOS High Mojave 10.14.2
2.8 GHz Intel Core i7 MacBook Pro Retina, 16 GB RAM
Pro Tools 2018.12
Apogee Duet (Firewire)
Old 02-22-2017, 10:00 AM
JFreak's Avatar
JFreak JFreak is offline
Opinions do vary, but I think it is best to connect mic to preamp and straight into A/D converter (interface). You can always compress later, but undoing is close to impossible
Janne
Old 02-22-2017, 10:16 AM
If I run Mic to Pre Amp to Interface I can use Pro Tools Compression while recording vocal & Compression will be dry? Right? Then I can Compress after vocal is recorded?
Can Compression from an outboard Compressor be added after the vocal is recorded? If so what is the best way to do it?
Thanks
Old 02-22-2017, 10:33 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
What I do is split the mike preamp output and feed an uncompressed track in addition to the compressed one. Then I use one or both in the mix.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 02-22-2017, 11:23 AM
That's interesting. How are you doing it? Are you using Outboard Compressors? Y cable? Or?
I'm using an outboard Vintech 273 Pre Amp which has 2 channels & a 2 channel DBX Compressor to a Presonus 16.4.2 Interface to PT 10.
Thanks
Old 02-22-2017, 02:44 PM
lvly5t lvly5t is offline
Yes you can send your recorded track to outboard gear i.e compressor post record. imo best way to do it. even as that guy said he runs both its a faster work flow to set up compression after recording especially with artists there because you want to track everything first then mix and edit. gives the artist more time to track than if you are setting up all your outboard gear before you even start to track
Old 02-22-2017, 10:03 PM
I like the idea of recording 2 tracks. One with Compression & one without. How do you run your cables?
Old 02-22-2017, 10:11 PM
JFreak's Avatar
Y-cable from the preamp output, one end straight to the interface and another to the compressor (which connects to the interface). Now you have two.
Janne
Old 02-23-2017, 04:40 AM
The Weed's Avatar
The Weed The Weed is offline
Some preamps have two outs. My single channel Grace m101 is one of them.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Vocal compression help Mattitude Tips & Tricks 14 03-18-2010 02:12 PM
Vocal Compression cdavis6406 Tips & Tricks 11 03-30-2008 05:28 AM
LE vocal compression Sharritan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-23-2005 05:30 AM
Compression for Vocal Daniel P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-27-2003 10:43 PM
Vocal compression Voutsonios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-03-2001 11:05 PM
