Old 01-17-2017, 12:50 PM
lucidlife lucidlife is offline
Default Possible to record cd played in iTunes?
I'm always getting cds, and recording snippets for samples. I'd like to be able to record audio from iTunes into PT.
Anyone know if something like this is possible?
Old 01-17-2017, 01:10 PM
zoff zoff is offline
Default Re: Possible to record cd played in iTunes?
Maybe I'm missing something, but can't you just drag files to the Track list window?
macOS High Mojave 10.14.2
2.8 GHz Intel Core i7 MacBook Pro Retina, 16 GB RAM
Pro Tools 2018.12
Apogee Duet (Firewire)
Old 01-17-2017, 04:37 PM
Well, I'd have to download the whole cd first, and then import the track I want. I rather just record the bit I want, without having to burn the whole cd
Old 01-17-2017, 05:08 PM
The Weed's Avatar
The Weed The Weed is offline
Out from your onboard soundcard into your PT interface.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-17-2017, 05:40 PM
ChuckS ChuckS is offline
If you're on a Mac: http://www.rogueamoeba.com/audiohijack/
PT 2019.6 DP 10.01 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1903)
PT 2019.6 DP 10.01 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6 (end of the OS road for the 2011 Mini)
Old 01-17-2017, 07:09 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Yes you can .., with Source Nexus
here is a link - the basic version is all you would need. You can record ANY system / or 3rd party app audio from your computer directly into Pro Tools
http://source-elements.com/products/source-nexus
Pro Tools 2018.1 Native * Slate Raven MTi-1 Version 3.3.0 * AVID MBox3 Pro * OSX Sierra 10.12.6 * MAC PRO (late 2013) * 3.5 GHz 6-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D300 2048Mb * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 (Broken !!! - shyte support from Blackmagic Singapore > A-Holes) * Samsung SSD's 850 Pro * WD Black HDD's
Old 01-17-2017, 08:08 PM
Drew Mazurek's Avatar
Just drag and drop the track you want from the Finder into ProTools and edit as needed.
www.drewmazurek.com
Old 01-18-2017, 05:26 AM
Sardi Sardi is offline
You say you want to record a snippet of a song as a sample, but you mention burning a CD. Confused...
As others have pointed out, simply copy the file from the CD in finder to your HD, import into PT and edit away. Takes like 20 secs max.
Old 01-18-2017, 06:39 AM
I think the OP meant "rip".
www.drewmazurek.com
Old 01-18-2017, 08:28 PM
The way it works is that iTunes will let you play the songs in iTunes, without the songs being on your HD, so they will not be in the finder.I would have to burn(rip) the cd, first then go into my finder then drag and drop from there into PT.
When you put a CD into your Mac a pop up appears asking if you want to burn the cd to your HD, if not then you can just listen to the songs in iTunes without them being in your HD.
It'd be easier to listen to the cd, then go into PT, play the portion of the song from the CD I want, and have it record into PT. Think of it as a piece of vinyl. When sampling from vinyl I'd play a portion of the song and record it into PT, through my interface(which I don't have. I'm just using my MacBook Pro atm), and then that'd be it. I'd get to work.
I've seen audioHijack, and used it! I love it! I was just wondering if there was a way I could do some internal routing, but that may not be the case.
So in conclusion, I'd like to be able to do that but with a CD, and no interface.
Manually played MIDI Notes arrive earlier than played. SmokinBaldMonkey macOS 5 10-06-2018 08:48 AM
Mix for TV played in a theatre Rizz Post - Surround - Video 7 10-31-2011 05:29 AM
Yes, he really played this! FordVan General Discussion 13 09-07-2010 04:15 PM
Problemas Itunes! / Problems Itunes-Mbox MEPHISTOX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-29-2008 05:37 AM
I HAVE PLAYED WITH THE 002 AT SAM ASH!!!!!! el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2003 12:08 AM
