Runtime C++ error w/list from tech support utility
Hi guys,
Ok i triied everything, but a full reinstall from scratch of the OS which I can't because I don't have the XP Disc. I have Ghost backups and I went way back when I *know* everything was working fine, it seems that everything started with my upgrade from 7.3 to 7.4 has to be something causing the error and I don't know what it is. I uninstalled Pro tools, clean everything deleted all the plugins with utility but it still crashes with the C++ error.. Here the list of what's installed hope you can help because is causing me delay in my work and i don't need it atm.. I also get the error "Could not save [name of the project] because Access violation occurred while translating tracks" of course when I try to save THanks in advance Version List as of Thu 09/18/2008 20:37:12.42 Pro Tools Version W32i APP ENU 7.4.0.309 shp protoolsle.exe Plug-In Versions c:\program files\common files\digidesign\dae\plug-ins\*.* W32i DLL ENU 4.2.1.150 shp !!!!!_sonyoxfordinflator.dpm - - - - - !!!!!_sonyoxfordinflator.dpm.rsr - - - - - .myscmserverinfo W32i DLL ENU 4.2.1.150 shp ampegsvx.dpm - - - - - ampegsvx.dpm.rsr W32i DLL ENU 7.0.0.0 dbg analog factory.dpm - - - - - analog factory.dpm.rsr W32i DLL ENU 7.4.0.168 shp bf essential clip remover.dpm - - - - - bf essential clip remover.dpm.rsr W32i DLL ENU 7.4.0.168 shp bf essential correlation.dpm - - - - - bf essential correlation.dpm.rsr W32i DLL ENU 7.4.0.168 shp bf essential meter bridge.dpm - - - - - bf essential meter bridge.dpm.rsr W32i DLL ENU 7.4.0.168 shp bf essential noise meter.dpm - - - - - bf essential noise meter.dpm.rsr W32i DLL ENU 7.4.0.290 shp bf essential tuner.dpm - - - - - bf essential tuner.dpm.rsr - - - - - bfd lite_runtime.log - - - - - [bombfactory] W32i DLL ENU 4.2.0.316 shp bombfactory bf-3a.dpm - - - - - bombfactory bf-3a.dpm.rsr W32i DLL ENU 7.4.0.168 shp bombfactory bf76.dpm - - - - - bombfactory bf76.dpm.rsr W32i DLL ENU 3.1.5.0 shp bombfactory-1176.dpm - - - - - bombfactory-1176.dpm.rsr W32i DLL ENU 3.1.5.0 shp bombfactory-la-2a.dpm - - - - - bombfactory-la-2a.dpm.rsr W32i DLL ENU 3.1.5.0 shp bombfactory-pultec-eqp-1a.dpm - - - - - bombfactory-pultec-eqp-1a.dpm.rsr W32i DLL ENU 7.4.0.117 shp broadband noise reduction le.dpm - - - - - broadband noise reduction le.dpm.rsr W32i DLL ENU 7.0.0.0 shp bt analog chorus ch2s-3.dpm - - - - - bt analog chorus ch2s-3.dpm.rsr W32i DLL ENU 7.0.0.0 shp bt analog phaser aph2s-3.dpm - - - - - bt analog phaser aph2s-3.dpm.rsr W32i DLL ENU 7.0.0.0 shp bt oilcan echo tle2s-3.dpm - - - - - bt oilcan echo tle2s-3.dpm.rsr W32i DLL ENU 7.0.0.0 shp bt stereo imager st2s-3.dpm - - - - - bt stereo imager st2s-3.dpm.rsr W32i DLL ENU 7.0.0.0 shp bt tempo delay dl3d-3.dpm - - - - - bt tempo delay dl3d-3.dpm.rsr W32i DLL ENU 7.0.0.0 shp bt valvedriver adr2s-3.dpm - - - - - bt valvedriver adr2s-3.dpm.rsr W32i DLL ENU 1.0.2.0 shp bx_control.dpm - - - - - bx_control.dpm.rsr W32i DLL ENU 7.3.0.117 shp chorus.dpm - - - - - chorus.dpm.rsr W32i DLL ENU 1.4.0.4 shp chrome_tone_(xp).dpm - - - - - chrome_tone_(xp).dpm.rsr W32i DLL ENU 7.3.0.117 shp click.dpm - - - - - click.dpm.rsr W32i DLL ENU 3.6.0.4 shp compressorbank_(xp).dpm - - - - - compressorbank_(xp).dpm.rsr W32i DLL ENU 4.2.0.316 shp cosmonaut voice.dpm - - - - - cosmonaut voice.dpm.rsr W32i DLL ENU 0.0.0.0 shp csr hall.dpm - - - - - csr hall.dpm.rsr W32i DLL ENU 0.0.0.0 shp csr inverse.dpm - - - - - csr inverse.dpm.rsr W32i DLL ENU 0.0.0.0 shp csr plate.dpm - - - - - csr plate.dpm.rsr W32i DLL ENU 0.0.0.0 shp csr room.dpm - - - - - csr room.dpm.rsr W32i DLL ENU 7.3.0.117 shp d-verb.dpm - - - - - d-verb.dpm.rsr W32i DLL ENU 7.4.0.309 shp digirewire.dpm - - - - - digirewire.dpm.rsr W32i DLL ENU 7.3.0.117 shp dither.dpm - - - - - dither.dpm.rsr W32i DLL ENU 7.4.0.179 shp dynamics iii.dpm - - - - - dynamics iii.dpm.rsr W32i DLL ENU 7.4.0.309 shp elastic audio.dpm - - - - - elastic audio.dpm.rsr W32i DLL ENU 7.3.0.117 shp eq iii.dpm - - - - - eq iii.dpm.rsr W32i DLL ENU 2.1.3.0 shp eqium.dpm - - - - - eqium.dpm.rsr W32i DLL ENU 4.2.0.316 shp fairchild 660.dpm - - - - - fairchild 660.dpm.rsr W32i DLL ENU 4.2.0.316 shp fairchild 670.dpm - - - - - fairchild 670.dpm.rsr W32i DLL ENU 3.1.5.0 shp fairchild-660.dpm - - - - - fairchild-660.dpm.rsr W32i DLL ENU 3.6.0.4 shp filterbank_(xp).dpm - - - - - filterbank_(xp).dpm.rsr W32i DLL ENU 7.3.0.117 shp flanger.dpm - - - - - flanger.dpm.rsr W32i DLL ENU 7.4.0.168 shp funk logic mastererizer.dpm - - - - - funk logic mastererizer.dpm.rsr - - - - - [hybrid] W32i DLL - 1.0.0.939 shp hybrid.dpm - - - - - hybrid.dpm.rsr W32i DLL ENU 7.3.0.117 shp invert-duplicate.dpm - - - - - invert-duplicate.dpm.rsr - - - - - [ixl] W32i LIB ENU 1.0.0.375 shp izotope_radius_win32.dll W32i DLL ENU 3.0.8.527 shp izozone3.dpm W32i DLL ENU 4.0.7.542 shp iztrash.dpm W32i DLL ENU 3.1.5.0 shp joemeek-compressor.dpm - - - - - joemeek-compressor.dpm.rsr W32i DLL ENU 3.1.5.0 shp joemeek-meequalizer.dpm - - - - - joemeek-meequalizer.dpm.rsr W32i DLL ENU 2.6.0.4 shp mc2000_(xp).dpm - - - - - mc2000_(xp).dpm.rsr W32i DLL ENU 7.3.0.117 shp mod delay ii.dpm - - - - - mod delay ii.dpm.rsr W32i DLL ENU 3.1.5.0 shp moogerfooger-analogdelay.dpm - - - - - moogerfooger-analogdelay.dpm.rsr W32i DLL ENU 3.1.5.0 shp moogerfooger-lowpassfilter.dpm - - - - - moogerfooger-lowpassfilter.dpm.rsr W32i DLL ENU 3.1.5.0 shp moogerfooger-phaser.dpm - - - - - moogerfooger-phaser.dpm.rsr W32i DLL ENU 3.1.5.0 shp moogerfooger-ringmodulator.dpm - - - - - moogerfooger-ringmodulator.dpm.rsr W32i DLL ENU 7.3.0.117 shp multi-tap delay.dpm - - - - - multi-tap delay.dpm.rsr W32i DLL ENU 7.3.0.117 shp normalize-gain change.dpm - - - - - normalize-gain change.dpm.rsr W32i DLL ENU 7.3.0.117 shp ping-pong delay.dpm - - - - - ping-pong delay.dpm.rsr W32i - - - - plugfixer.exe W32i DLL ENU 7.0.0.0 shp program eqp-4.dpm - - - - - program eqp-4.dpm.rsr - - - - - [pspaudioware] W32i DLL ENU 4.2.0.316 shp pultec eqh-2.dpm - - - - - pultec eqh-2.dpm.rsr W32i DLL ENU 4.2.0.316 shp pultec eqp-1a.dpm - - - - - pultec eqp-1a.dpm.rsr W32i DLL ENU 4.2.0.316 shp pultec meq-5.dpm - - - - - pultec meq-5.dpm.rsr W32i DLL ENU 7.3.0.117 shp reverse-dc removal.dpm - - - - - reverse-dc removal.dpm.rsr W32i DLL ENU 3.1.5.0 shp sansamp-psa-1.dpm - - - - - sansamp-psa-1.dpm.rsr W32i DLL ENU 7.3.0.117 shp signal generator.dpm - - - - - signal generator.dpm.rsr W32i DLL ENU 7.3.0.117 shp signaltools.dpm - - - - - signaltools.dpm.rsr W32i DLL ENU 7.4.0.117 shp smack! le.dpm - - - - - smack! le.dpm.rsr W32i - - - - sonalksis cq1 mono.dpm - - - - - sonalksis cq1 mono.dpm.rsr W32i - - - - sonalksis cq1 stereo.dpm - - - - - sonalksis cq1 stereo.dpm.rsr W32i - - - - sonalksis dq1 mono.dpm - - - - - sonalksis dq1 mono.dpm.rsr W32i - - - - sonalksis dq1 stereo.dpm - - - - - sonalksis dq1 stereo.dpm.rsr W32i - - - - sonalksis sv-315mk2 mono.dpm - - - - - sonalksis sv-315mk2 mono.dpm.rsr W32i - - - - sonalksis sv-315mk2 stereo.dpm - - - - - sonalksis sv-315mk2 stereo.dpm.rsr W32i - - - - sonalksis sv-517mk2 mono.dpm - - - - - sonalksis sv-517mk2 mono.dpm.rsr W32i - - - - sonalksis sv-517mk2 stereo.dpm - - - - - sonalksis sv-517mk2 stereo.dpm.rsr W32i - - - - sonalksis tbk3 mono.dpm - - - - - sonalksis tbk3 mono.dpm.rsr W32i - - - - sonalksis tbk3 stereo.dpm - - - - - sonalksis tbk3 stereo.dpm.rsr W32i DLL ENU 7.4.0.117 shp soundreplacer.dpm - - - - - soundreplacer.dpm.rsr W32i DLL ENU 3.1.5.0 shp tel-ray-variable-delay.dpm - - - - - tel-ray-variable-delay.dpm.rsr - - - - - test.bin W32i DLL ENU 7.3.0.117 shp time comp-exp-pitch shift.dpm - - - - - time comp-exp-pitch shift.dpm.rsr W32i DLL ENU 7.4.0.270 shp time shift.dpm - - - - - time shift.dpm.rsr W32i DLL ENU 7.3.0.117 shp timeadjuster.dpm - - - - - timeadjuster.dpm.rsr W32i DLL ENU 7.3.0.117 shp trim.dpm - - - - - trim.dpm.rsr W32i DLL ENU 1.0.2.1 shp urs 1970 compressor native.dpm - - - - - urs 1970 compressor native.dpm.rsr W32i DLL ENU 1.0.0.4 shp urs 1975 compressor native.dpm - - - - - urs 1975 compressor native.dpm.rsr W32i DLL ENU 1.0.2.1 shp urs 1980 compressor native.dpm - - - - - urs 1980 compressor native.dpm.rsr W32i DLL ENU 2.0.0.10 shp urs a mix eq native.dpm - - - - - urs a mix eq native.dpm.rsr W32i DLL ENU 2.0.0.9 shp urs a series eq native.dpm - - - - - urs a series eq native.dpm.rsr W32i DLL ENU 2.0.0.9 shp urs a10 series eq native.dpm - - - - - urs a10 series eq native.dpm.rsr W32i DLL ENU 2.0.0.9 shp urs blt eq native.dpm - - - - - urs blt eq native.dpm.rsr W32i DLL ENU 2.0.0.9 shp urs fulltec eq native.dpm - - - - - urs fulltec eq native.dpm.rsr W32i DLL ENU 2.0.0.10 shp urs n mix eq native.dpm - - - - - urs n mix eq native.dpm.rsr W32i DLL ENU 2.0.0.9 shp urs n series eq native.dpm - - - - - urs n series eq native.dpm.rsr W32i DLL ENU 2.0.0.9 shp urs n12 series eq native.dpm - - - - - urs n12 series eq native.dpm.rsr W32i DLL ENU 1.1.2.0 shp urs strip native.dpm - - - - - urs strip native.dpm.rsr W32i DLL ENU 1.0.0.35 shp urs strip pro native.dpm - - - - - urs strip pro native.dpm.rsr W32i DLL ENU 1.1.0.0 shp vocal_wavesshell-dae 1.1.dpm - - - - - vocal_wavesshell-dae 1.1.dpm.rsr W32i DLL ENU 3.1.5.0 shp voce-chorusvibrato.dpm - - - - - voce-chorusvibrato.dpm.rsr W32i DLL ENU 3.1.5.0 shp voce-spin.dpm - - - - - voce-spin.dpm.rsr W32i DLL ENU 7.0.0.0 shp vw1973 eq.dpm - - - - - vw1973 eq.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwbx_digital.dpm - - - - - vwbx_digital.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwclassic delay.dpm - - - - - vwclassic delay.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwclassic reverb.dpm - - - - - vwclassic reverb.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwd-pole.dpm - - - - - vwd-pole.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwd-pole_.dpm - - - - - vwd-pole_.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwdfh sampler.dpm - - - - - vwdfh sampler.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwdr. device.dpm - - - - - vwdr. device.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwe-retrovox.dpm - - - - - vwe-retrovox.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwe-tubetape warmer.dpm - - - - - vwe-tubetape warmer.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwevent horizon+.dpm - - - - - vwevent horizon+.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwgrungelizer.dpm - - - - - vwgrungelizer.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwlisten mic compressor.dpm - - - - - vwlisten mic compressor.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwmajor tom.dpm - - - - - vwmajor tom.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwoxford eq native.dpm - - - - - vwoxford eq native.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwoxford limiter native.dpm - - - - - vwoxford limiter native.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwroommachine844.dpm - - - - - vwroommachine844.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwtapestop.dpm - - - - - vwtapestop.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwtg12413 1969.dpm - - - - - vwtg12413 1969.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwtg12413 2005.dpm - - - - - vwtg12413 2005.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwtransient monster.dpm - - - - - vwtransient monster.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwwarpvst.dpm - - - - - vwwarpvst.dpm.rsr W32i DLL ENU 7.0.0.0 shp vwx-cita.dpm - - - - - vwx-cita.dpm.rsr W32i DLL ENU 5.0.3.0 shp waveshell-dae 5.0.3.dpm - - - - - waveshell-dae 5.0.3.dpm.rsr W32i DLL ENU 5.0.1.0 shp waveshell-dae 5.0.dpm - - - - - waveshell-dae 5.0.dpm.rsr W32i DLL ENU 5.2.0.0 shp waveshell-dae 5.2.dpm - - - - - waveshell-dae 5.2.dpm.rsr W32i DLL ENU 5.3.0.0 shp waveshell-dae 5.3.dpm - - - - - waveshell-dae 5.3.dpm.rsr W32i DLL ENU 5.5.0.0 shp wavesshell-dae 5.5.dpm - - - - - wavesshell-dae 5.5.dpm.rsr W32i DLL ENU 5.7.0.0 shp wavesshell-dae 5.7.dpm - - - - - wavesshell-dae 5.7.dpm.rsr - - - - - wavesshell-dae 5.7.dpm.xml W32i DLL ENU 5.9.5.1 shp wavesshell-dae_5.9.5.1.dpm - - - - - wavesshell-dae_5.9.5.1.dpm.rsr W32i DLL ENU 5.9.5.0 shp wavesshell-dae_5.9.5.dpm - - - - - wavesshell-dae_5.9.5.dpm.rsr W32i DLL ENU 5.9.6.0 shp wavesshell-dae_5.9.6.dpm - - - - - wavesshell-dae_5.9.6.dpm.rsr W32i DLL - 1.0.1.984 shp xpand!.dpm - - - - - xpand!.dpm.rsr c:\program files\common files\digidesign\dae\plug-ins\bombfactory\*.* - - - - - bomb factory owner's manual.pdf c:\program files\common files\digidesign\dae\plug-ins\hybrid\*.* - - - - - [phrases] - - - - - [wavetables] c:\program files\common files\digidesign\dae\plug-ins\hybrid\phrases\*.* - - - - - 000 arpeggios - - - - - 001 basses - - - - - 002 melodic - - - - - 003 plucked - - - - - 004 rhythmic - - - - - 005 up+down c:\program files\common files\digidesign\dae\plug-ins\hybrid\wavetables\*.* - - - - - 000 core wavetables c:\program files\common files\digidesign\dae\plug-ins\ixl\*.* W32i DLL ENU 1.0.1.0 shp ixl clip statistics.dpm - - - - - ixl clip statistics.dpm.rsr W32i DLL ENU 1.0.1.0 shp ixl level meter(h).dpm - - - - - ixl level meter(h).dpm.rsr W32i DLL ENU 1.0.1.0 shp ixl level meter.dpm - - - - - ixl level meter.dpm.rsr W32i DLL ENU 1.0.1.0 shp ixl multimeter.dpm - - - - - ixl multimeter.dpm.rsr W32i DLL ENU 1.0.1.0 shp ixl spectrum analyzer.dpm - - - - - ixl spectrum analyzer.dpm.rsr W32i DLL ENU 1.0.1.0 shp ixl stereo analyzer.dpm - - - - - ixl stereo analyzer.dpm.rsr c:\program files\common files\digidesign\dae\plug-ins\pspaudioware\*.* W32i DLL ENU 7.3.0.0 shp psp neon.dpm - - - - - psp neon.dpm.rsr Plug-Ins (Unused) Versions Music Production Toolkit W32i DLL ENU 7.4.0.309 shp musicproductiontoolkit.dll DV Toolkit 2 is not installed. Digitranslator is not installed. DV Toolkit 1 is not installed. |
Re: Runtime C++ error w/list from tech support utility
You have a lot of incompatible plug-ins installed. Update them, trash prefs and try again.
Here's the info on compatible plug-in versions: http://digidesign.com/index.cfm?navi...n=news_details The assertion error can likely be fixed by trashing databases. You can find info on that in the General Troubleshooting thread. |
Ok I did check the list and for the life of me I haven't seen ONE plugin that is listed as NC.. Could you kindly point 'em?
Also I uninstalled some plugin that i wasn't anyway using that much uninstalled averything and reinstalled PT, now it seemed to go but when I saved I got the "Access violation occurred" I checked my HD and i noticed that all the folders are "read only" but not really, they are not checked, they are kind of greyed out, if i deselect the read only option it comes back immediately.. What's that? And please I re-checked and I cant really find incompatible plugins.. |
W32i DLL ENU 4.2.0.316 shp bombfactory bf-3a.dpm - - - - - bombfactory bf-3a.dpm.rsr W32i DLL ENU 3.1.5.0 shp bombfactory-1176.dpm - - - - - bombfactory-1176.dpm.rsr W32i DLL ENU 3.1.5.0 shp bombfactory-la-2a.dpm - - - - - bombfactory-la-2a.dpm.rsr W32i DLL ENU 3.1.5.0 shp bombfactory-pultec-eqp-1a.dpm - - - - - bombfactory-pultec-eqp-1a.dpm.rsr W32i DLL ENU 1.4.0.4 shp chrome_tone_(xp).dpm - - - - - chrome_tone_(xp).dpm.rsr and so on.... |
OK thanks now I understood what i have to check
And this:
And: Quote:
Dude, seriously??? You will have a MUCH smoother time with your Pro Tools experience, and have MUCH better luck getting things to work properly if you stop using illegal software! I'm guessing this is more of it, as this is a very old version of this plugin: Quote:
Posting on a public forum where everyone in the world (including the companies that you are ripping off) can see that you are using them, that's just plain... well... insert your favorite word for "not smart" .
& da church said "amen"...
Tech Support Utility Fail | audiogeekzine | Pro Tools M-Powered (Win) | 2 | 08-23-2010 07:20 PM |
Bugs in Tech Support Utility | bblue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-29-2009 05:23 AM |
Tech support utility in PT8 | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-26-2008 08:42 PM |
DIGI...Tech Support Utility error | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-22-2008 07:36 PM |
Tech support utility | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-04-2007 12:00 AM |
