Old 01-18-2017, 08:31 PM
lucidlife lucidlife is offline
Default Re: Possible to record cd played in iTunes?
Originally Posted by Seafoam_Green View Post
Yes you can .., with Source Nexus
here is a link - the basic version is all you would need. You can record ANY system / or 3rd party app audio from your computer directly into Pro Tools
http://source-elements.com/products/source-nexus
Seems like exactly what I want! I'll check it out.
Dang $125 is out of my pr atm. There has to be something like this but free.
Thanks
Old 01-18-2017, 08:34 PM
DontLetMeDrown DontLetMeDrown is offline
Can you use iTunes when PT is open? On my system PT locks down all the audio so that nothing else can use it. For your workflow, you may want to considering investing in a CD player with a digital output that you can feed directly into your interface inputs.
Old 01-19-2017, 01:34 AM
ChuckS ChuckS is offline
Originally Posted by lucidlife View Post
I've seen audioHijack, and used it! I love it! I was just wondering if there was a way I could do some internal routing, but that may not be the case.
Rogue Amoeba also has a product for routing called Loopback (http://rogueamoeba.com/loopback/).
PT 2019.6 DP 10.01 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 1903)
PT 2019.6 DP 10.01 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6 (end of the OS road for the 2011 Mini)
Old 01-19-2017, 04:56 AM
zoff zoff is offline
The way it works is that iTunes will let you play the songs in iTunes, without the songs being on your HD, so they will not be in the finder.I would have to burn(rip) the cd, first then go into my finder then drag and drop from there into PT.
When you put a CD into your Mac a pop up appears asking if you want to burn the cd to your HD, if not then you can just listen to the songs in iTunes without them being in your HD.
Thats not true. When you insert a CD the files appear in iTunes and also in the Finder.
One way to do it is:
In Finder Preferences, go to Show these items in the sidebar, under Devices check CD, DVD etc.
macOS High Mojave 10.14.2
2.8 GHz Intel Core i7 MacBook Pro Retina, 16 GB RAM
Pro Tools 2018.12
Apogee Duet (Firewire)
Old 01-19-2017, 10:29 AM
They may show in Finder but you can't just drag them to a track - they're not regular audio files.
Old 01-19-2017, 10:45 AM
Really!? I've never had that problem.
Any Audio CD will have its files show up as AIFF audio files in the Finder since Mac OS 7 at least.
Pro Tools 2018.12
Old 01-19-2017, 11:40 AM
Extreme Mixing Extreme Mixing is offline
Yes. It's been a while since "Import Audio From Other Movie".
Steve Shepherd
Extreme Mixing
Old 01-19-2017, 11:50 AM
DetroitT's Avatar
DetroitT DetroitT is offline
AudioEase "Snapper"
They have a 100 day trial.
Spots to folder or apps like Pro Tools/ Has a slew of sample prep tools.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 01-19-2017, 06:09 PM
john1192 john1192 is offline
wow .. that has been awhile ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 01-20-2017, 06:05 AM
Okay - I'll admit that much. However if I try dragging these files into or importing into Adobe Audition it locks up Audition and I know AA can work with aif/aiff files. Why it does that I have no idea but it happens consistently. Therefore I rip and then drag to wherever I need the file.
Manually played MIDI Notes arrive earlier than played. SmokinBaldMonkey macOS 5 10-06-2018 08:48 AM
Mix for TV played in a theatre Rizz Post - Surround - Video 7 10-31-2011 05:29 AM
Yes, he really played this! FordVan General Discussion 13 09-07-2010 04:15 PM
Problemas Itunes! / Problems Itunes-Mbox MEPHISTOX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-29-2008 05:37 AM
I HAVE PLAYED WITH THE 002 AT SAM ASH!!!!!! el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2003 12:08 AM
