How to find out what codec i'm missing?
Just went from 10.6 and pt 8 to yosemite and pt 11, everything seems fine but I apparently have a missing codec and can't play any video.
I'm very bad with codecs, how is the easiest way to find out what im missing? Is there a way to see all the codecs i have installed? |
Re: How to find out what codec i'm missing?
There is a codec installer in the PT installer in the folders below the drag to applications folder area. But I have been using QuickTime X to convert movies that don't seem to work with PT. Open the movie in QT then select "Export To" then select 720 or 480 movie. This will creat a copy in the same directory and make the file type a .mov and should work in PT. I use 720 and it really doesn't change the resolution.
thanks! already had a .mov file but after reexporting with quicktime it worked.
Need to find missing article | ronmark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-14-2007 03:50 PM |
Missing codec | helloo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-07-2006 05:23 AM |
Quick Time Movie Fails to Import Missing Codec | Sitruc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-09-2005 11:45 AM |
Avid Codec missing | h1ntOn | Post - Surround - Video | 6 | 04-07-2005 08:01 PM |
troublesome bouncing- > .wav to wmp missing codec? | Mariachi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-02-2004 09:12 AM |
