installation and startup problems
Hi All,
I work for Univ of CA at Santa Barbara. we recently bought an upgrade of PT from 6.7 to 7.3.1. Went to install the new software, and the installer would install everything fine up until it reached the Pro Tools Utilities, upon which point it would give an installation error. So, ultimately, i think the Utilites did not get installed, which may be causing the next problem... When attempting to start PT, i get the error message "Pro Tools with TDM requires the TDM Mixer plug-in in the plug-ins folder." The program then quits itself. Was this error message regarding the TDM mixer plugin due to the fact that the Utilities wouldn't install right? What are the chances that I got a bad copy of the installation DVD from Digidesign, causing the utilities installation to fail? and, most importantly, what can i do to remedy the situation? This software is in use by many students, so to have it not working in the lab is really not good...Is there an installer around that will install just the utilities, or maybe will Digidesign allow me to download a PT 7.3.1 HD installer image? Help! Thanks, Tim Beutler CREATE Dept, University of CA, Santa Barbara |
Re: installation and startup problems
Tim,
Un-install PT7 using the DVD. Make sure your plugs and any custom i/o setups are backed up first. You are going to wipe your PT install. trash all database and pref files. empty trash, restart. Then re-install. All better now?
--Jeremy |
PT9 Installation Odyssey--Insecure Startup Item Disabled | Peter Baird | macOS | 0 | 05-15-2011 10:34 PM |
PT 8 startup problems | fransmo | Pro Tools M-Powered (Mac) | 1 | 11-12-2009 03:04 PM |
Error with startup after installation of Melodyne | jeto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-26-2009 06:02 PM |
Startup Problems | wfenlon | Tips & Tricks | 3 | 01-25-2008 08:32 AM |
G4 733 / OS 9.2.1 startup problems!!!!!!! | electroluky | Pro Tools TDM Systems (Mac) | 16 | 03-21-2002 12:14 AM |
