Old 11-09-2017, 04:21 AM
stefanboman stefanboman is offline
Default Odd screen behaviour
After updating to 3.7 the 4th screen of my 32ch S6 behaves differently.
I've cleared all the "dedicated screens" in the arrangement window.
But sometimes the screens show different amount of rows of information.
Screens 1-3 looks right. But the 4th is often a bit different.
Sometimes shows an extra row(like sends or eq curves) when the others don't.
How do I get back to the old screen behaviour?
Old 11-09-2017, 06:43 AM
creativecontrol's Avatar
Default Re: Odd screen behaviour
Greetings,
So - your 4th display module is definitely not declared at a Master Meter Module, right? If you look at the surface page - the icon representation for an MMM is slightly different (dashed lines going perpendicular) than a standard display module.
When you bank and nudge is the 4th display showing the correct track's information? If you toggle the Display View from the User Settings between the different display module views does the 4th display module follow?
Let us know. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-09-2017, 07:33 PM
EddieJones's Avatar
EddieJones EddieJones is online now
I think you may either be seeing a bug we have discovered or saved the state of the meters in Layouts?
If you cycle through the global meter types does it fix it ?
Old 11-09-2017, 11:34 PM
Never tried the saved state in layouts.
In the arrangement page, all the screen all icons look the same.
The screen banks as expected.
When the screens are cycled thru the different display modes it won't help.
Its like screen number 4 has the current display mode + an offset of one.
So if screens 1-3 shows one row of info at the bottom screen 4 shows two.
Attached a pic.
Old 11-10-2017, 04:22 AM
Also - if these were manually changed to a different display module view then they would ignore the global view changes. Try using Attention switch + Select for any of the channels in that bucket to individually step through the display views. If you hold Attention + Select for a few seconds the channel's display should revert back to the default view.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-10-2017, 04:57 AM
Thanks for the tipp Jeff!
Didn't know I could do that.
But no luck... Works on displays 1-3. But not on display 4.
Old 11-10-2017, 08:59 AM
EddieJones's Avatar
Do you have any Attention Expand Modules assigned below that screen ?
Old 11-10-2017, 12:27 PM
Ah ****, yes I do.
Didnt cross my mind cause I stole one knob module to keep in the middle.
But it’s mapped to channels 25-32.
Any way to have the screen not react to that?
Old 11-10-2017, 01:37 PM
EddieJones's Avatar
Not at the moment, in v3.8 it has been improved a little so it doesn't switch if it doesn't need to.
Compatibility with screen readers and screen enlargers mrhonor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-20-2009 10:14 AM
7.2 new behaviour I don't like Dan Pinder Pro Tools TDM Systems (Mac) 4 08-14-2006 12:06 PM
Strange Behaviour from Mix|Plus & 888|24's Richard Conrad Pro Tools TDM Systems (Mac) 2 01-01-2005 11:56 AM
HELP! Screen Freezes (just screen) While Running 6.1.1 on XP Home Brentsky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-27-2004 08:54 AM
001 Irratic Behaviour tapedoctor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-05-2002 08:18 PM
