Grid in ticks or tuplet divisions
I'm doing polyrhytmic music, so I use lot of tuplets: triplets, quintuplets, sextuplets, septuplets, etc.
I would like set grid value to different tuplet value or just in ticks. I haven't found way to do that. Is pro tools grid values limited to only regular note values: quarternotes, eightnotes, 16th notes and triplets, etc. ? Or have I missed something? I know that quantization is possible with tuplet values, how about grid settings? I would just want draw and edit midi within self chosen grid. Please somebody help to answer to this question. thanks, Mikko |
Re: Grid in ticks or tuplet divisions
MBox2Pro / LE 8.0.5 |
IDK, but sounds interesting. Post a link to your music?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thanks for your replies. No problems of changing Time Signature, but If I want to build a piece where is for example quintuplet pulse over triplet pulse, then I would need to select different grid values for to draw midi. So I wasn't actually talking about changing meter. I'll post some day link to this music (-:
Mikko |
Don't know if you can have different grid assignments on different tracks at the same time - but you could just change the grid assignments to the appropriate value as you get to each track - it's not pretty but it will work.
Cheers, Scott |
At the top of your edit window click the grid drop down arrow and check 3triplet for whatever subdivision you want. 1/8, 1/16. etc.
PT doesn't do arbitrary tuplets, but I'm pretty sure Reaper does. It's a lot more convenient to do MIDI in, anyway. And you can Rewire multiple outputs from Reaper into PT for mixing. Your soft synths will be more stable, too.
Please explain, as I do not (yet) use Reaper. Thanx !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Reaper is a fairly new, inexpensive DAW. Not quite as pro as PT LE yet but gaining ground quickly. You can dload a demo with full funcionality, just a nag screen until you buy. One big advantage is it runs VSTs. Combine that with ReWire functionality, and it makes a great team member with PT, especially if you do a lot of MIDI stuff. I'm pretty sure it allows any rational grid, and even some irrational ones.
I have the same exact problem as you! It seems that PT oly allows you to set on 1/8, 1/16, 1/32, 1/64 and their dotted and triplet values. What if I need a quintuplet or seventuplet? And, please, don't answer us to change metre, that's not what we need to do! An irregular n-tuplet has nothing to do with the metre of the music, as a sixteenth quintuplet can be inserted in a regular 4/4 pattern!
Thank you GS |
Hotkey for cycling through time divisions (bars:beats, min:sec) | jschmidtiii | macOS | 2 | 04-03-2013 06:34 AM |
Slip to Grid mode no visual grid unless pressing "grid" | mgoorevich | Pro Tools 9 | 5 | 11-13-2010 07:11 AM |
The Click and manipulating sub divisions. | Monty_python | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-05-2009 03:28 PM |
Click - Changing Sub-Divisions - Double TIme | John Pisciotta | Pro Tools TDM Systems (Mac) | 2 | 03-06-2008 12:58 PM |
Timing (Tuplet) question for RAIL | Ke productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 03-03-2004 06:56 PM |
