Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #101
Old 11-14-2020, 07:41 PM
dez811 dez811 is offline
Default Re: Worst Dark Mode Ever
once I set my monitor to gaming mode I can more than tolerate dark mode it looks great! I'm using the samsung SJ55W Ultra WQHD Monitor
  #102
Old 11-14-2020, 07:43 PM
SomeOtherGuy SomeOtherGuy is offline
Okay, here's the deal. I said I liked dark mode and I do, but that was before I tried to edit MIDI in the MIDI Editor. You can't see anything because there's no contrast--everything is dark. This a definite NO GO.
Also in the main Edit window, you can't see the bar lines. They should be a bright color like white, light gray, or yellow so they stand out.
Dark Mode needs some practical tweaks; surprised it went out like this.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
  #103
Old 11-14-2020, 07:52 PM
rampartthemovie rampartthemovie is offline
someone found a way to manipulate the dark theme colors from a text file and some other stuff, maybe one can explore more:
"in the folder: Avid\Pro Tools\Skins\Dark
There is PTColors.txt, it has numbers that means (Red, Green, Blue, Alpha). In the first image example, DarkModeClips and DarkModeAutomation is set to 0 which changes the tracks to be non-dark mode. Nothing else changed, there are a crap ton of paremeters, would be curious to what people come up with because I didnt touch anything or experiment with the other paremeters yet."
  #104
Old 11-14-2020, 09:59 PM
In Logic you have the option to select either light background or dark background in the MIDI graphic editor as well as the the main edit window, while everything else remains dark. I'd really like this choice for Pro Tools too.
  #105
Old 11-14-2020, 11:40 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Yes! The MIDI Editor is the big draw for Dark Mode
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
  #106
Old 11-15-2020, 12:46 AM
apparently there is a way to modify all elements of the UI alongside the skin txt file, this in theory we could modify elements of the dark mode alongside normal mode:
Videos of it in action:
Orange Transport Edition
https://streamable.com/272odr
Rainbow Sherbert edition:
https://streamable.com/rccl5o
  #107
Old 11-15-2020, 01:02 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by Akiz View Post
I have no clue. But by a brief search i did, found this info below, hope it works.
How to Change an Application Icon.
-Move the cursor to the Results panel, and right-click the desired application.
-Select Properties.
-On the General tab, click Change Icon.
-Select the desired icon, or browse to another location to select the icon. After you've selected the icon, click OK. The new icon appears in the Results panel.
Cheers!
Thanks
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #108
Old 11-15-2020, 01:35 AM
doublehook's Avatar
doublehook doublehook is offline
Default Re: I hope they fix night mode on Windows 10
Yeah, it's very disappointing. Why even make the dark theme available on Windows if you only get half the mode? It's like a half blend of classic and dark thrown together. Why would anybody want to use this in an unfinished state? ¯\_(ツ)_/¯
Pro Tools Ultimate (2020.11) | Avid Omni HD | Windows 10 | i7 4930k | 64 GB RAM | Neve MBP | SSL Alpha Channel | Warm Audio WA 76 | SSL G Comp | A Designs Hammer | Electrodyne 511 | Dbox
Plugins: Slate | Waves Mercury | Fab Filter | Sonimus | Toneboosters | BlueCats | IK | UAD | & Everything else...
  #109
Old 11-15-2020, 04:40 AM
Care to post a link where you saw your info? Also what is the exact path on a Mac - been looking all over and can't find the folder you mentio.
Jack
QAPLA!
  #110
Old 11-15-2020, 06:14 AM
Philthy Philthy is offline
Originally Posted by DontLetMeDrown View Post
I shared this pic in another thread. This is why I'm hating dark mode on Windows 10. Seems more like afternoon mode with all those white bars. PT is my only app that does this with the OS in dark mode, with MS office apps being the exception.
Yikes that looks bad. And ProTools already looked really bad under Windows to begin with.
Phil Mann
Silk City Music Factory - CT Recording Studio
"Dark" theme improvements in 2021.3 midnightrambler Pro Tools 19 04-04-2021 05:15 AM
How to change Pro Tools 12 to a Dark theme/skin Defier Pro Tools 12 7 03-26-2016 05:22 PM
Pro Tools 8 theme for Reaper? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-09-2010 07:51 AM
Pro tools theme song....! roijin Pro Tools TDM Systems (Mac) 2 11-27-2001 07:15 AM
