Old 03-21-2019, 02:54 AM
robreed2 robreed2 is offline
Default Logic 10.3.1 with latest EUCON..ERROR message
Please update EuCon.
Current EuCon version: 4.0.7 build 244
Minimum EuCon build: 65,916
Ive unisinstalled everything and tried it again same message..I can ignore this message and use Logic, but its not stable...
IS IT because I haven't got the latest version of LOGIC running with it..
Should I use an earlier version of EUCON>>
I can't run latest LOGIC 10.4 cos my MAC PRO won't run it..???
Bit of a pain....
Old 03-22-2019, 08:54 AM
EddieJones's Avatar
Default Re: Logic 10.3.1 with latest EUCON..ERROR message
Apple fixed this...update Logic
Old 03-22-2019, 10:54 AM
Hi Eddie
I cant update Logic's it won't run on my MAC... only on the latest macs...
It needs to made clear in Avids system requirements, that the latest EUCON will only work with the latest Logic, which APPLE require you have to have the latest MACS..
Suppose I have now resigned myself to not ever having a working system...Unless I drop a few thousand $$$$ to make my Artist Mix stable.... not good really>!
Old 03-22-2019, 02:18 PM
EddieJones's Avatar
The message is a bug...there is a number miss match in the versions thats all. It doesnt mean Logic is saying it doesnt work.
Old 03-22-2019, 03:33 PM
Are we saying it has no baring on the stability of LOGIC>? Great if that is the case..
Old 03-23-2019, 08:21 AM
EddieJones's Avatar
No this is just a message comparing EUCON versions and the numbers got mixed up, has no baring on the software.
Incompatible EuCon version Logic Pro X message. SevenRising Avid S1, S3, Dock and Control App 12 03-14-2018 03:17 PM
Incompatible EuCon version message with 3.7 and Logic Pro 10.3.2 on Mac OS 10.12.6 _scott_ Artist Series 9 11-30-2017 04:12 AM
Error Message with Eucon 3.2 KeyplayerG Artist Series 2 07-14-2015 05:42 AM
Weird Error message with Logic/PT Hardware logandrum Pro Tools TDM Systems (Mac) 2 10-15-2005 02:07 PM
logic+digi001+error message 6031 juhadrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-21-2001 06:43 AM
