Old 06-05-2016, 12:46 PM
Sparky1 Sparky1 is offline
Default Exporting Clips as Files
Hey there.
I'm a little uncertain about this function...
I have used this function in the past to export clips - to be used in another PT session.
Then I would bounce the song to be used in things such as CD's or iPods etc..
If I imported a song into a session - say to cut or add blank space to a song's beginning or end - would I need to bounce this song out or would I be able to use the export clips function... and have it playable as a .wav on a CD or in an iPod...?
Thanks,
Sparky
Old 06-05-2016, 02:29 PM
Drew Mazurek's Avatar
Default Re: Exporting Clips as Files
Originally Posted by Sparky1 View Post
Hey there.
Thanks,
Sparky
You could bounce to get it out of PT as one file, or use "Consolidate Selection" to render your edits into one file that would then be in the Audio Files folder.
www.drewmazurek.com
Old 06-05-2016, 03:47 PM
Thanks for the reply - but still not 100% certain I understand...
If it exists in the Audio file bin - does it need to be "bounced" out of the bin to be used...?
Sparky
Old 06-05-2016, 03:58 PM
Sparky
If it's the bit depth and sample rate you need, you can simply drag/copy the file for whatever purpose. But if you need 16/44.1 and your session is 48, then you'd need to bounce or do the consolidation/export method I posted before.
www.drewmazurek.com
Old 06-05-2016, 04:06 PM
Excellent.... thanks!
Sparky
Pro Tools 12.4 won't export Clips as Files Spyderrp7 Pro Tools 12 3 04-02-2016 01:18 AM
Trouble exporting clips as interleaved soundpalace Pro Tools 12 10 03-12-2016 10:42 AM
Can't export clips as individual files lucidlife Pro Tools 12 3 02-17-2016 01:54 PM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Pro Tools 10 Freezing While Exporting Clips mugmugmug Pro Tools HDX & HD Native Systems (Mac) 1 01-23-2013 05:18 AM
