Importing audio files
Error MP3 for forum.PNGHello, I originally had a macbook pro that had no problems with this. I now have a Windows 10 AMD A10. But the problem I am having is I want to import mp3 files (i.e. drum tracks from youtube, etc.) but I get an error message at the bottom of the window [screenshot attached to this thread]. Hallllp. thanks.
Re: Importing audio files
Here is another error I'm getting
Warning, not a PC user, have never owned one......
But..... Isn't there an issue with Quicktime and Win10? I remember hearing that somewhere. |
The message says: "QuickTime is not installed."
Is it actually installed? IIRC, there is an Avid Knowledgebase regarding QuickTime being an issue if it is installed after Pro Tools is installed. Cheers,
Indeed, I would install iTunes and Quicktime(they are free) and see if that helps. Then, how are you downloading audio from youtube? Whatever add-on you use is saving the audio in a format that Pro Tools does not recognize, so either try a different converter, check to see if what you have has other options for output format, or find out what kind of file is being saved, and search for a converter that will read and convert those files to something that PT does recognize
Importing audio files for remix - convert or set session to match source audio? | LSW | Tips & Tricks | 22 | 09-09-2014 09:28 PM |
Importing audio files in PT 11 | Idealmusic | Pro Tools 11 | 9 | 06-09-2014 11:32 PM |
Importing audio files | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-06-2008 08:56 AM |
importing audio files | kurtb | Pro Tools M-Powered (Mac) | 0 | 12-22-2007 11:11 PM |
Importing Audio Files | bigcow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-14-2003 04:32 PM |
