Help With Outputs - Audition Path
I'm having an issue with my outputs on Protools 11.3.1. I want to be able to use my entire interface outputs to run individual tracks or stems through.
However, when I use outputs 1-2 for, say, a drum stem, the entire daw session is running through those channels. I've tried changing my audition paths and my default output bus and it's still unchanged. I've read through the manual on this subject as well and it doesn't say much regarding this. Am I limited to only using 14 outputs? Or is there a way that I can use 1-2 without having to hear the entire session through them? Thanks for your help |
Re: Help With Outputs - Audition Path
Hi, What interface are you using? You should be able to set your mix to go out through any physical output or bus if your I/O is set up properly to do so, and your audio tracks are set to send the mix out the channels you want it to. Maybe if you could post a screenshot of your Output page of the I/O setup and a screenshot of your Mix window that would help.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I'm using a FF800. It has 8 analog outputs, but does not have the separate monitor outputs that my 002 had. Opening the Fireface settings page doesn't help either. It doesn't have anything to adjust analog outputs; only analog inputs and phantom power settings etc
What does your output page in the Pro Tools I/O Setup look like?
Might be time to familiarize yourself with TotalMix.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Hello. I wanted to open this conversation again.
here is a screenshot of my input/outputs. I've been using every analog output and (but the DAW MAIN output) and 8 adat outputs for summing into my 1202. Funny thing is that even when all my tracks are routed to the other outputs and the main bus meter is Protools is showing no activity, I am still hearing the entire mix coming out of my DAW MAIN output through the DAW MIX input on my monitor mixer. How is it that all of my tracks, being routed through other outputs, are still coming through the Main 1-2 output? Why does the entire mix come through 1&2, even through I only assign certain tracks to stem out through it? This means I can only use 14 channels of summing, instead of 16. Help? |
"you need to have a valid audition path in I/O setups to audition" - HELP ! | Riquier | Pro Tools M-Powered (Mac) | 5 | 04-29-2014 02:34 PM |
Audition Path | jamiecer | Pro Tools TDM Systems (Mac) | 2 | 06-16-2008 09:14 PM |
Audition Path | Felix Rost | Pro Tools TDM Systems (Mac) | 0 | 03-14-2007 05:53 AM |
Audition Path in PT7 | innesireinar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-31-2005 10:47 AM |
Can I use my digital outputs with Audition Path? | davey boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 11-14-2005 10:25 AM |
