Old 06-25-2013, 04:56 PM
Default Re: Reason 64 bit via rewire?
Originally Posted by guitardom View Post
I honestly dont think so. I have been rewiring reaper since v2
But Rewire itself didn't go 64 bit until just a couple of versions ago.
Jack
QAPLA!
Old 06-25-2013, 05:19 PM
zedhed's Avatar
zedhed zedhed is offline
Maybe he means using it up to PT10 (32bit)?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 06-25-2013, 06:01 PM
I would imagine so. PT10 and previous incarnations only needed 32 bit Rewire which existed since time immemorial AFAIK.
Jack
QAPLA!
Old 06-26-2013, 09:23 AM
drumzalicious drumzalicious is offline
This is my concern. Reason is my main source for MIDI sounds and I use rewire all the time. If I don't have to upgrade from Reason 4 then I don't want to.
Old 06-26-2013, 10:06 AM
That depends on whether you're not going with PT11 and also on exactly when Rewire protocol changed to 64 bit. Don't know if you can update just the Rewire protocol separately from Reason.
You won't lose anything from Reason 4 with going to Reason 7 - in fact you gain a bunch of stuff. You should be able to open anything from a Reason 4 session in Reason 7.
Jack
QAPLA!
  #16
Old 06-26-2013, 10:08 AM
Actually it was fairly recently w Reason 6 it all went 64 bit isn't it??? I am using 6.5 and forgot to consider that part.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #17
Old 06-27-2013, 04:13 PM
Kachunk Kachunk is offline
Originally Posted by docric View Post
Hey Kachunk,
Yep, worked a little on it yesterday.... Win7pro 64, reason 6.5 64bit, PT 11 demo (non HD)....
Showed up under "Instruments" as normal... No fancy installation hoops taken. The demo is actually on our "b" room comp that uses reason 6.5 & the balance interface. PT 11was surprisingly solid on this all day yesterday.
Unfortunately, this doesn't really aid in solving your prob...
Rick,
Do you recall the order of install? Did you have PT 10.3 on there, for instance, and upgraded to 11 to have both versions? What about Reason, did you uninstall the 32bit version or just install the 64bit reason on "top"? Reason installed before or after PT?
Sorry for all the questions, still struggling with it and I'm now wondering if the order/procedure is important.
  #18
Old 06-27-2013, 04:46 PM
K Roche's Avatar
K Roche K Roche is online now
Originally Posted by Kachunk View Post
Still struggling with this. Thanks for the replies.
In Windows you have to go out of your way to install the 32 bit version of Reason (using /32 option), so I'm confident I have the 64 bit version of Reason.
Humm except that to run Reason in PT 10 on down, it has to run in 32 bit, regardless of what your computer is running. Also at least in Reason 6.5 (which is what I have) the selection to launch in 32 is done in Reason, not the OS So I'm wondering if you need to go back into Reasons preferences and change it to 64
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #19
Old 06-28-2013, 08:47 AM
Riskozero76's Avatar
Riskozero76 Riskozero76 is offline
I'm assuming that I will need to upgrade my version of Reason since I'm still on v4 for it to be compatible with Pro Tools 11?
Yes, you will have to upgrade.
I had the same problem, still have though, but I'm a little closer to fix it since I installed Reason 7.
  #20
Old 06-28-2013, 10:00 AM
My concern is more in the cost. Currently trying to upgrade a few other things as well and this would be another thing on the list. Joys of music eh?
Rewire with Reason 5. supergirl36 Pro Tools 9 1 10-09-2011 12:59 PM
Reason Rewire josh87 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2007 06:02 PM
rewire reason in PT HELP!!!!!! Livin' Proof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-20-2007 12:04 PM
Help With Reason and Rewire rockwithrespect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-05-2004 04:51 PM
Reason? Rewire? dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-11-2003 11:17 AM
