Asio device properties have been changed...
Hello everyone, I've been having this problem ever since I hooked up my new console Tascam DM-3200. I have to keep rebooting Pro tools almost every hour. Message is as follow:
"Asio device properties have been changed by the device central panel. Protools must be restarted for these changes to take effect. Please restart pro tools" I have tried the following: disable internet, disable realtek audio device, disabled printer ports. I also updated my Nvidia Graphics card. I noticed the problem happens when the screen have no more signal, once back I get this protools message. Has anyone had this problem? I am using Protools 10, Tascam DM-3200 with firewire card in expansion slot. Computer is P4 i5 3.0ghz. Thanks Guitarbin |
Re: Asio device properties have been changed...
Make sure nothing else is running (iTunes, etc.). Are you connecting anything digitally to the mixer? Make sure its clock is set to master.
I have seen several people in the last 3 weeks with Tascam issue
Drivers ?
ASIO device properties error for a noob | jon superdeath | Windows | 14 | 11-12-2017 11:50 PM |
ASIO device properties have been changed by the device control panel. | medinarawk | Third Party Interfaces | 5 | 07-06-2015 02:18 PM |
'ASIO Device has changed properties' is back with avengeance. | TheJamsh | Third Party Interfaces | 13 | 09-29-2013 10:40 PM |
AISO properties have been changed in the device panel | YYR123 | Windows | 30 | 09-08-2013 08:01 AM |
DICE chipset+PT10="ASIO device properties have been changed by the device" | Funk-O-Meter | Windows | 5 | 12-19-2012 05:12 PM |
