Old 01-28-2013, 03:05 PM
amoretam amoretam is offline
Default select soloed tracks
there has to be a way to do this!
When I mix, it is part of my workflow to solo tracks (randomly) to tweak them as needed, then all of a sudden I need to solo just one track (to listen carefully).. The problem is that I loose my previous soloed tracks and i have to start all over ( and remember which ones were soloed).. Do you know what i mean?
I want to be able to get back to my previous soloed tracks..
For example I discovered this actions in Reaper which i can use to select soloed tracks, un-solo all, and solo just the track I want, and then...as all of my previous soloed tracks are selected... I can get back to solo them...
Am I being clear.... This actions in Reaper are just beautiful for my workflow...and can be done very spontaneous without having to create groups.
..but I am mixing in protools now and I need a way todo this....
so please people give me some ideas...
Thanks a lot
Old 01-29-2013, 09:10 AM
daeron80 daeron80 is offline
Default Re: select soloed tracks
Start with all tracks muted. Unmute tracks one by one. When you want to solo a track, solo it. Upon unsoloing it, you'll be right back to your "soloed" set.
Optionally, select the set of tracks you want to solo and press Shift-S.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 01-29-2013, 09:24 AM
that is really a pain,, when I mute all tracks (option+click) all tracks are muted, (master tracks returns, etc...)..
It is a wate of time to go there and unmute only those tracks I don't need to be muted, (master, returns ,etc)..
thanks
any other ideas people?
Old 01-29-2013, 12:16 PM
zoff zoff is offline
thanks
…sorry, don't have any suggestions, but Mute Groups would be the way to go.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 01-29-2013, 12:39 PM
would you please share how to create groups with just mute assigned to them....? (protools 9)
Thanks
Old 01-29-2013, 12:43 PM
Thanks
Sorry, I wasn't being clear. Mute Groups was just a wish for a future version of Pro Tools, AFAIK there is no way to do it ATM.
Old 01-30-2013, 07:18 AM
Oh, sorry, I didn't mean mute every single track - only the audio source tracks. If you organize your tracks by placing all aux returns and such at the far right (or left), you can almost instantly select all the source tracks with Shift-click, and then press Shift-M. Boom. Ready to start unmuting one by one. Not that that's an approach I'd generally recommend. It can be helpful once in a while for a particularly busy or cluttered arrangement. But usually, you'll get a better mix by make all decisions in the context of the big picture.
David J. Finnamore
Old 01-30-2013, 07:19 AM
Unless I misunderstand you, PT does do mute groups. Select the tracks you want in the group, group them, and uncheck all but mutes in the dialog. Solo groups work the same way. Or a group can be for both mutes and solos. Or sends. Or solos and sends. Etc. Highly flexible.
David J. Finnamore
Old 01-30-2013, 08:56 AM
You are right. I haven't been using Pro Tools much in the last year, how quickly I forget.
I like your sig.
How to select all tracks in the edit window d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-07-2021 09:18 AM
Select tracks by color? jschmidtiii macOS 2 05-09-2013 02:56 PM
Can't select just on track, selects all tracks dwilliam Pro Tools M-Powered (Win) 5 01-11-2007 09:37 AM
How To Select All Tracks & Delete a Bridge Aten Pro Tools TDM Systems (Win) 1 11-06-2006 09:49 PM
How to select reigons on multiple tracks StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-06-2003 11:58 AM
