Old 11-16-2012, 03:00 PM
realizment realizment is offline
Default Single track to multiple tracks or aux
Hey I'm getting a little confused here. When I have vocals I like to create a lead bus (aux) sometimes I want to parallel one single lead track and also send it to one other track to create exciter. Is the only way to do this by setting the outputs to unused bus then setting input on aux to unused bus. Then for any additional I have to use a send on the channel itself? Am I making sense here?
Thanks guys!
Old 11-16-2012, 05:04 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Single track to multiple tracks or aux
If you want to keep the original track in the mix, leave the output set to Main and create a send (or multiple sends...up to 5) to bus to another channel/s with the input on any track/s receiving on corresponding bus.
If you don't want the original track in the mix; ie you want just the processed track/s in the mix, create send/s and set original track output to either no output or corresponding bus. Bare in mind, if you set main output to a bus, there is no need to create a send unless you want it to go to multiple busses/tracks.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 11-16-2012, 11:28 PM
Appreciate it thanks!
mixing multiple tracks to a single stereo track billardis Windows 2 10-12-2013 04:36 PM
sliding tracks (single and multiple)... how the heck? stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-08-2009 03:19 AM
Drag multiple files on a single track??? sand Tips & Tricks 4 08-20-2002 11:11 PM
multiple destinations to a single MIDI track Fave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-09-2002 08:25 AM
Multiple CD tracks from single file ThB Music Digidesign Hardware & Software 0 09-15-1999 10:54 PM
