Old 08-23-2009, 01:24 PM
nicholasivan nicholasivan is offline
Default Help! Hybrid Blank Screen
I'm running Hybrid 1.5.2 on PT LE 8.0. The plug-in basically works. It passes audio and midi and I am able to change presets. But the hybrid plug-in window is just a blank screen. I cannot adjust any parameters. It has been like this since I was on PT 7.4.2. When I open my session on my PT HD2 system, it comes up fine. Anyone else had this problem?
Old 08-24-2009, 08:07 PM
Default Re: Help! Hybrid Blank Screen
Well...I drug the Hybrid plug-in (.dpm) into the trash, rebooted the computer, put it back in place and...voila! It works now. Crazy, huh?.
Old 08-30-2009, 11:13 AM
amauribr amauribr is offline
It didn't worked for me...
Old 09-01-2009, 01:10 AM
oulablank oulablank is offline
If you are running Structure or Structure free with Hybrid in the same session, one will be blank ( the one that is opened second ) The way to fix this is to download a different ( or lower ) version of Structure and it will work fine. If you don't have Structure then it beats me !
Old 09-01-2009, 04:36 AM
Yeah it seems to be an incompatibitily between structure and hybrid.
So we cannot open both at the same session.
Digidesign is working on it?
Old 09-01-2009, 04:03 PM
Well...I guess I spoke too soon. Next time I went to open Structure, it was blank...I got around that one by importing another session's file that had structure in it. Then when I went back to the original Hybrid session, that was blank again too. It does seem to be intermittent. I have the full structure version. I did not intentionally install the free structure ever - I owned structure before I installed this PT system. Maybe the free structure came with PT when I bought it?
Old 09-02-2009, 10:57 AM
I've never installed Struture free as well...
Old 09-15-2009, 07:39 PM
spur's Avatar
spur spur is offline
Wow this has been bothering me so much. I finally logged in to see what the matter was. Made my Structure Free track "Inactive," Quit ProTools LE and relaunched, re-opened my session, and my beloved Hybrid is back in business!
I certainly won't be using Structure any time soon.
What an oversight....
Thank you, Forum!!
Cheers,
Nathan
memesounds.com
Old 09-18-2009, 03:59 PM
jackshocklee jackshocklee is offline
I have the screen come up, but all the preset sounds are not showing up. Before the 8.0.1, they were, but now they won't. All my other A.I.R. instruments are working great. I can pull the instruments up by the pull down menu in hybrid, but there is nothing in the sound bank preset screen. Any suggestions? Thanks.
Jack
Old 11-17-2010, 04:58 PM
I am still experiencing this problem over a year later. I have been working around it, but it's very frustrating. Does anyone have an idea if Digidesign / AIR are going to do anything about the incompatibility of Hybrid and Structure?
Digi 003 lcd screen is blank Skeme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2013 06:14 PM
Hybrid Shows Up Blank Brent Paschke Virtual Instruments 1 02-05-2010 05:45 PM
DIGI 003 Screen is BLANK Soundwave0789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-15-2008 03:21 AM
PT7.3 new session blank screen lodnum Pro Tools TDM Systems (Mac) 3 01-23-2008 08:47 AM
blank gray screen on tilt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-09-2007 03:40 PM
