#421
Re: PT8 CPU Usage
We don't see this problem on our machines, so we need to try to commonalities between the systems experiencing it. |
#422
Re: PT8 CPU Usage
All recommended XP optimizations in place. Sandra report as follows :- >>>> SiSoftware Sandra Computer Model Workgroup : WORKGROUP Host Name : carillon User : David M. Lang Processor Model : Intel(R) Pentium(R) 4 CPU 2.66GHz Speed : 2.67GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Integrated Data Cache : 8kB, Synchronous, Write-Thru, 4-way, 64 byte line size, 2 lines per sector L2 On-board Cache : 512kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector Computer Mainboard : Intel D845PESV BIOS : Intel Corp. SV84510A.86A.0013.P08.0303171920 03/17/2003 Bus(es) : X-Bus AGP PCI IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DDR Chipset Model : Intel 82845G/GL/GE Brookdale Host-Hub Interface Bridge (B1) Front Side Bus Speed : 4x 133MHz (532MHz) Total Memory : 2GB DDR Memory Bus Speed : 2x 222MHz (444MHz) Memory Module(s) Memory Module : Micron 16VDDT12864AY335F2 1GB DDR PC2700U DDR-166 (2.5-3-3-7 2-10-0-0) Memory Module : Micron 16VDDT12864AY335F2 1GB DDR PC2700U DDR-166 (2.5-3-3-7 2-10-0-0) Video System Video Adapter : RADEON 7000 SERIES (VS1.1 166MHz, 64MB 166MHz, AGP 2.00) Video Adapter : RADEON 7000 SERIES (VS1.1 166MHz, 64MB 166MHz, AGP 2.00) Storage Devices ST380011A (80GB, ATA100, 3.5", 2MB Cache) : 75GB (C:) (D:) ST380011A (80GB, ATA100, 3.5", 2MB Cache) : 75GB (E:) GENERIC IDE CARD READER (ATAPI) : N/A (H:) _NEC DVD_RW ND-3520A (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:) Logical Storage Devices Removable Drive (H:) : N/A @ GENERIC IDE CARD READER (ATAPI) SYSTEM (C:) : 20GB (NTFS) @ ST380011A (80GB, ATA100, 3.5", 2MB Cache) ARCHIVE (D:) : 55GB (NTFS) @ ST380011A (80GB, ATA100, 3.5", 2MB Cache) AUDIO (E:) : 75GB (NTFS) @ ST380011A (80GB, ATA100, 3.5", 2MB Cache) Optical Drive (I:) : N/A @ _NEC DVD_RW ND-3520A (ATA33, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Intel 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge LPC Legacy Controller 1 : SMSC LPC47M172 Audio Device : Xilinx RME Digi96/8 Pad Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : Intel 82801DB/DBL (ICH4/ICH4-L) UltraATA/100 EIDE Controller Disk Controller : Adaptec AHA-2904/Integrated AIC-7850 USB Controller 1 : Intel 82801DB/DBL USB UHCI Controller #1 (ICH4/ICH4-L B0) USB Controller 2 : Intel 82801DB/DBL USB UHCI Controller #2 (ICH4/ICH4-L B0) USB Controller 3 : Intel 82801DB/DBL USB UHCI Controller #3 (ICH4/ICH4-L B0) USB Controller 4 : Intel 82801DB/DBL USB 2.0 EHCI Controller (ICH4/ICH4-L B0) FireWire/1394 Controller 1 : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller FireWire/1394 Controller 2 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. >>>> David |
#423
Re: PT8 CPU Usage
I got a significant improvement from changing visual effects from "best performance" to "best appearance" which somebody here on the DUC had noticed.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#424
Re: PT8 CPU Usage
Thought I'd chime in and finally be able to say thanks to Digi. It's been a long time coming but my PT8 is now running fine on my laptop I am experiencing the program focus issue that others have mentioned relating to CPU usage but for right now it's not an issue for me. I can do what I need to finally. If the focus issue does become a problem for me, I'll be back.
Again, thanks Digi for making things right (mostly). |
#425
Re: PT8 CPU Usage
still a little buggy
#426
Re: PT8 CPU Usage
I see some of the graphics issues on my system. Does anyone know if it was supposed to have been addressed in 8.01 or is it being worked?
SiSoftware Sandra Computer Model : Gigabyte EP35-DS3L Workgroup : WHITESTABLE Host Name : e8400 User : lcpr Processor Model : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed : 3GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Gigabyte EP35-DS3L BIOS : Award (Phoenix) F5 07/16/2008 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 DDR3 Chipset Model : Giga-Byte P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 2GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Corsair CM2X1024-6400C4 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400C4 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : NVIDIA GeForce 8400 GS (16 SP 1.4GHz, 512MB DDR2 2x500MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8400 GS (8SP 1.4GHz, 511.7MB 2x500MHz) Storage Devices ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) : 298GB (G:) (H:) (I:) ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) : 298GB (C:) (D:) (E:) TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices system320AS (C:) : 78GB (NTFS) @ ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) data (D:) : 117GB (NTFS) @ ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) archive (E:) : 103GB (NTFS) @ ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) system320NS (G:) : 59GB (NTFS) @ ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) data320 (H:) : 117GB (NTFS) @ ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) archive320 (I:) : 122GB (NTFS) @ ST3320620NS (320GB, SATA150, 3.5", NCQ, 16MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte (ICH9) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte (ICH9) HD Audio Controller Audio Device : VIA M Audio Delta-44 Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte (ICH9) 2 port Serial ATA Storage Controller 1 Disk Controller : Giga-Byte (ICH9) 2 port Serial ATA Storage Controller 2 Disk Controller : Giga-Byte JMB368 IDE Controller USB Controller 1 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 2 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 3 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 4 : Giga-Byte (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 6 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 7 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 8 : Giga-Byte (ICH9) USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP LaserJet 1020 (600x600, USB) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#427
Re: PT8 CPU Usage
Can you be more specific about which 'graphics issues' you're experiencing? |
#428
Re: PT8 CPU Usage
sometimes when i go to the mix window the mix window comes out black
#429
Re: PT8 CPU Usage
this is my major CPU pet peeve though: http://duc.digidesign.com/showthread...wpost&t=255295 CPU pegs at 100% after saving a session (even a blank session) whenever the edit window is minimized. This happens every time.. not some random "once in a while" type bug. |
#430
Re: PT8 CPU Usage
I dont know if this is just typical with PT or is an issue. I have tried this with other things on my system, and I do not see anything similar in any other program I have (Cubase 4.52, REAPER, etc). I mean there is of course CPU usage, but not the order of magnitude that PT seems to have. All the examples are with Windows Task Manager open to "Performance" so I can see the CPU usage trends. Idle is about 3% not doing anything, regardless if the PT window has focus or not. I don't have any problems with latency, playing / recording audio etc. Program feels very solid. Examples: If I open the score editor and add a few notes (this in a new project, nothing else), I get 20-40% CPU usage as I drag or enter the notes on the score. Seems exhorbitant usage to me, but I am new to PT. If I insert the PT EQ and turn a knob I get 40% spikes while I turn the knob. That kind of stuff. Just seems like there is some issue with the PT graphics. Like I said, this does NOT happen with *any* other program. |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
Help understanding CPU Usage, RAM, Disk Usage... | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 02-03-2006 07:41 PM |
HTDM not showing CPU usage in the system usage | Brandonx1 | Pro Tools TDM Systems (Win) | 3 | 12-19-2004 09:45 AM |
CPU usage | Room24Prod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-16-2004 06:20 PM |
DSP Usage? | Smithtrax | Pro Tools TDM Systems (Mac) | 1 | 10-15-2003 02:13 PM |
