mbox 2 connecting to a mixer
hello, in simple terms please explain. I want to connect my mbox 2 to a mixer but when i try to connect through s/pdif it makes a constant ringing sound through the speakers.also when i connect my triton to the regular connection it makes a ringing (quieter) sound as well. dont know why. extremely frustrated. probably going to pay for studio time. thanks for your time and concern. Justin [email protected] [email protected]
Re: mbox 2 connecting to a mixer
I'm not quite following you. Does your mixer have an SP/DIF input? If not, it is a typical analog mixer and you need to connect your Mbox to it using the Mbos's analog outs to one of the analog inputs on the mixer.
As for the Triton, are you connecting the analog outputs to the mixer's analog inputs? SP/DIF is a digital format and does not work with analog connections?
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
yes my mixer has s/pdif inputs, and i am coonecting the triton properly because i can record, it just rings real quiet for some reason.(like there is to much power going into it.).the mixer only supports 300 watts, maybe that's the problem?
Just for the sake of sanity, which mixer are you using?
sorry bout that, new 2 this. but it is a PV 14 (peavey)
Ummmm... the PV14 does not have S/PDIF. Those are line level RCA connectors; Analog Audio connectors.
S/PDIF is a digital audio format. It uses the same size RCA connectors, but the format is TOTALLY different. You cannot connect the RCA jacks of the PV14 to the S/PDIF rca jacks on the MBox. They are two totally different things.
oh that's not good. thanks for the helpful info. i guess there's no way to connect the two ?
any clue about the triton? because i am hooking it straight to the mbox and getting a ringing sound. and yes it is hooked into the right places.thanks
Connecting a mixer to my Mbox | advision205 | Tips & Tricks | 7 | 04-08-2012 09:46 AM |
Connecting Mixer to Mbox | Kapp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-23-2011 04:10 PM |
Connecting m box 2 with mixer? | futurepast | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-17-2007 09:46 AM |
mbox 2 connecting 2 mixer | jahlive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-26-2006 03:06 PM |
Connecting a mixer to my mBox (newbie questions) | Redglittercoffin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-26-2004 02:45 PM |
