CPU usage
Is the CPU usage meter hard drive, processor, or ram related? For instance if I keep adding plugins and the CPU usage goes up, am I taxing the processor itself? Or the hard drive? Or the RAM?
Digi 002R Factory Bundle P4 2.4 Ghz 1MB Cache 1GB PC3200 Dual-Channel DDR RAM 40GB HDD for OS 250GB HDD for Audio (2) 17" Monitors |
Re: CPU usage
CPU = Central Processing Unit
You decide
Re: CPU usage
I know what CPU means. lol
I was just asking as to what specifically Pro Tools is metering. Are there things you can do to help offset the CPU usage? Would adding more RAM and faster hard drives act as relief to the CPU usage?
Re: CPU usage
The meter is the use of the P4 2.4 Ghz processor in your computer.
I would ask: Have you tweaked your Windows OS completely, are you using a SATA/SCSI drive for the audio drive and have you thought about getting a larger CPU. There are tweaks within PT itself, have you used them? ... and there are about a gazillion other things I can think of, if I gave it the time. Windows can be a pain and uses resources you don't even think about (run/services.misc, for example). I use a combination of tweaking guides ... but I would say go check out these guys sites, www.blackviper.com, lot's of useful info there, or www.musicxp.net ... I do believe, they have lots of good info there, too. Hope that helps you some more with your problem.
were humans involved ... if so, I can believe almost anything! |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
Help understanding CPU Usage, RAM, Disk Usage... | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 02-03-2006 07:41 PM |
HTDM not showing CPU usage in the system usage | Brandonx1 | Pro Tools TDM Systems (Win) | 3 | 12-19-2004 09:45 AM |
5.3.3 on XP Pro and CPU usage | Ken P | Pro Tools TDM Systems (Win) | 0 | 09-03-2004 10:19 AM |
DSP Usage? | Smithtrax | Pro Tools TDM Systems (Mac) | 1 | 10-15-2003 02:13 PM |
