Old 10-31-2004, 05:34 AM
Tim R. Tim R. is offline
Default Audio to MIDI (for drum triggering)
Hello all,
I've used sound replacer in the past, but with the the HUGE onset of drum instruments on the market (BFD, DFH, Drumcore Reason drums) that all have HUGE velocity maps and often embedded samples, how can we generate MIDI tracks from our recorded drum tracks? While at Digiworld this weekend I heard the Reason demo guy mention in passing that this was possible with Beat Detective, but I don't recall this functionality. Am I missing something here? Is this new to 6.7?
Tim
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 10-31-2004, 06:02 AM
kcurry kcurry is offline
Default Re: Audio to MIDI (for drum triggering)
Beat Detective has been part of TDM for quite a while now. I don't remember which specific version it cropped up in. Your info is correct that Beat Detective can create a tempo map from an audio track where there are clear sharp transients. You should probably take a quick look at the manual section covering Beat Detective prior to messing with it. I'm not in front of PT right now, but check around in your menus. If you are using LE, I understand that Beat Detective will be part of LE in 6.7, which is supposed to be available for download next week.
Old 10-31-2004, 06:16 AM
aux aux is offline
Or the old-fashioned method: use an Alesis D4 drummachine and route the audio through it's trigger inputs. Record the MIDI that is outputted.
Aux
MassiveMusic
SOS article
Old 10-31-2004, 10:08 AM
TCDet TCDet is offline
Use Melodyne or recycle(export midi)
Melodyne also works well for charting melody lines.
Old 11-01-2004, 05:02 AM
Sorry, but you've misunderstood my original post. I'm fully aware of beat detective's TEMPO Mapping ability. What I'm looking for is AUDIO TO MIDI with amplitude to velocity (no pitch is needed).
Tim
Tim Reisig
Old 11-01-2004, 08:17 AM
Seeee Seeee is offline
Logic.
Old 11-01-2004, 08:24 AM
roberts roberts is offline
I'll second Logic as well it works very good.
Old 11-01-2004, 09:58 AM
So what's the cheapest version of Logic that will do this? This all seems like such a PITA.
DIGI, couldn't you guys come up with a viable solution? Even if it was rolling it into Soundreplacer (thus not cutting into those sales).
Tim
Logic.
Tim Reisig
Old 11-01-2004, 08:22 PM
Bump, Digi? Any thoughts?
Tim
Logic.
Tim Reisig
Old 11-01-2004, 08:39 PM
Howardk Howardk is offline
I'd love to have an audio to midi generator as well. . . Why get a piece of hardware like the DM4 for such as basic function?. . . I use my Pad 8 but it is takes more time to get it out and hook it up than actually doing the deed. . . a little utility/plugin would be handy. . .
...for system configuration info see my profile
(Click on member name)
Drum replacement - midi triggering Freezestudio macOS 2 10-28-2011 01:46 AM
Triggering MIDI sounds through drum pad JohanMN MIDI 2 09-03-2010 02:33 AM
Midi Triggering Drum Samples Kenny Gioia Pro Tools TDM Systems (Mac) 26 12-07-2008 07:01 PM
Triggering midi drum samples from audio files? abchurch MIDI 0 03-12-2007 11:43 AM
Triggering drum sounds from audio tracks c-tone Pro Tools TDM Systems (Mac) 19 01-20-2007 10:23 AM
