No clip light in meters after upgrade?
I finally upgraded my stuff all the way to 5.1.1 last night and everything seems to be solid and stable.
However, I've noticed that the meters will not indicate a clip input anymore. I can bury the meter into the yellow range with a +4 source, but I can't ever get the red clip indicator to set. But I can hear that indeed, I've certainly maxed it out. This is while monitoring inputs with low-latency or regular latency engaged. Metering is set to pre-fader. I even tried upping the gain on the inputs in the engine settings, but no difference in the red clip indicator. So what is going on here? |
Re: No clip light in meters after upgrade?
What does the meter read when you set it for post-fader?
Does this happen only when you record or when you boost the level of a track that has already been recorded?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I can get the clip indicator when playing back, or when metering post fader.
However I can't seem to hit it on pre-fader metering, which is where I'd find it useful. |
edit window not showing clip on a meters | dmitri85 | Pro Tools 11 | 9 | 10-25-2014 03:03 PM |
clip red light? | calle.vs | Post - Surround - Video | 8 | 08-04-2009 03:57 PM |
888 gets too hot?-Meters to full clip-stops workin | berk42 | Pro Tools TDM Systems (Mac) | 4 | 08-23-2005 05:23 PM |
clip light & tracking | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-24-2003 01:52 AM |
the little red clip light | defretman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-26-2003 12:57 AM |
