Old 06-17-2019, 07:51 AM
Nearzy17 Nearzy17 is offline
Default Pro Tools first crashing
I am trying to use pro tools first on my home pc (r7 1700, gtx 1070, 16gb hyperx ddr4) and when I launch pro tools for the first time it says that I need to select a play back engine so when I press playback engine the program crashes, no error, Pro Tools just closes. and no holding N doesn't do anything. Thanks in advanced
Old 06-17-2019, 07:56 AM
jeam25's Avatar
jeam25 jeam25 is online now
Default Re: Pro Tools first crashing
Hi please check what interface is using windows as default playback device . And select other than the one its gonna be using Protools . Also check with asio4all driver if that doesn't work .
- Jesus Alvarado -
Keep the volume UP !
Old 06-17-2019, 07:58 AM
what do you mean by check what interface is using windows as default playback
Old 06-17-2019, 08:00 AM
jeam25's Avatar
Right click the speaker beside to the hour and check this ( image )
- Jesus Alvarado -
Old 06-17-2019, 10:46 AM
The Weed's Avatar
The Weed The Weed is online now
Do you have an interface? You need something that Pro Tools can use for I/O. On Windows you need an interface with an ASIO driver, or use ASIO4All with your on board sound card (although that is far from ideal).
Demos: brucehayward dot com
Source-Connect: brucehayward
Pro Tools Crashing 11.1.2 on OSX 10.5.8 mzkguy macOS 2 09-18-2014 05:51 AM
help pro tools s e crashing onebloodcujo Pro Tools SE and Essential (Win) 0 02-11-2012 10:24 PM
Please help ! Pro tools crashing.... Grom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-28-2008 12:10 PM
AAF Crashing Pro Tools delaplanemusic Pro Tools TDM Systems (Mac) 3 05-17-2008 12:36 AM
Pro Tools crashing... Friday 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2006 07:18 PM
