Old 05-17-2019, 03:27 AM
mark12318 mark12318 is offline
Default Creating a Stem as a Single WAV File, NOT FluteR, FluteL
Hello Everyone:
Although I've created stems before, I typically get a series of audio file with names such as FluteR, FluteL, TrumpetR, TrumpetL. I then import these files into a new session of Pro Tools and everything works fine.
However, I now need to created stereo stems. The above example would be shown as Flute (stereo), Trumpet (stereo), etc. I would then import 2 files (Flute, Trumpet) into a new session of Pro Tools.
Any ideas?
Thanks in advance,
Mark A. Ross
Old 05-17-2019, 03:36 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Creating a Stem as a Single WAV File, NOT FluteR, FluteL
In the bounce / export menu, there's an option for Mono / Multi-mono and interleaved.
You probably want interleaved, then the stereo files will be combined as 1 file
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-17-2019, 03:44 AM
Hi Chris:
Thanks so much for your response. I'm not sure I expressed myself as clearly as I intended.
What if a I have 10 audio files in my session and I need to create 10 stereo WAV files. I can't use TptR TptL, but rather I need to get Tpt, Piano, etc (each as a single Wav file.
Any ideas?
Thanks,
Mark
Old 05-17-2019, 03:51 AM
amagras amagras is offline
That's exactly what Chris says, read it again
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-17-2019, 04:29 AM
I definitely follow what Chris is saying and I appreciate your help.
I tried his suggestion and got a single *.WAV with all of the audio tracks on that single WAV file.
My question is this: What if you have 10 audio tracks that you wish to export, and you want EACH track to be a single WAV file for each of those tracks.
The resultant audio file folder would show the following:
Tpt.wav
Piano.wav
violin.wav
Thanks in advance,
Mark
Old 05-17-2019, 05:17 AM
You have to SOLO the track of the instrument you want to export otherwise Pro Tools will export the whole mix.
amagrasmusic.com
Old 05-17-2019, 05:46 AM
Perfect - now I follow
Thanks again for sticking with the issue and resolving it so nicely.
Regards,
Mark
Old 05-17-2019, 07:17 AM
You will find better and easier ways to do that as you spend more time on PT and well be happy to help.
amagrasmusic.com
When creating a template.ptxt file is it a stand alone self contained file? xrekcor Pro Tools 2018 9 12-23-2018 11:14 PM
Help Creating STEM please. LSJ Pro Tools TDM Systems (Mac) 7 02-10-2011 06:47 PM
how does one bounce out a single 6 channel stem tunespin Post - Surround - Video 2 11-19-2009 09:43 PM
Copying single tracks from one file to another new file Room335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2008 11:55 AM
Creating a loop or looping a single track ? Tubelover 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 06-21-2002 06:28 PM
