Ok, hope you can help - again
So, i went out and got a power amp and a monitor today, when I have the Eleven rack connected via XLR to the power amp and then via speaker cable it loses sound when Pro tools is engaged.
When I have the eleven rack connected to the power amp via guitar cable, Pro tools works fine (the monitor is connected the same both ways). So, I'm thinking there is a command somewhere that allows me to tell pro tools that I'm using XLR, not a guitar cable but i can't find any documentation anywhere. Anyone have any suggestions? I'm using an Imac via USB for Pro tools. |
Re: Ok, hope you can help - again
so, no one has an idea on why the sound goes out when I turn on Pro Tools and XLR connections are used?
Do you have the output setup correctly?
Read through the manual, its a PDF so you can search for your exact question http://akmedia.digidesign.com/suppor...v90x_71670.pdf
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I've read the manual cover to cover and can't find any reason why i cant hear anything while in pro tools and connected by XLR
Sent from my Xoom using Tapatalk |
This is because in the PT 11R window under "user settings" (I believe), there are options that ask where you want your output signal to go - like DAW, Digital outs, etc. You have to toy with it and get the one that gives you the output you're looking for.
I Am Jamsire |
I did that and nothing happened, I went through all of them without any luck I'm new to digital recording, what do you mean by "arm the track"? |
But yeah, you won't hear any input sound in PT unless the track is armed. (that little button pressed)
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
You can also go here: http://www.avid.com/US/support/customer-assist Choose the 11R, then the TUTORIALS tab. Watch all the vid's and you should have a better understanding of how Pro Tools works.
Wow, this is a pretty bad feature, I mean it completely effects the response and tone of the guitar through the 11R. How does this allow for competent manipulation of the rigs? |
Please help, I hope I'm not SOL | Osmin Camero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-20-2008 01:16 PM |
I hope someone can help... | trkkazulu | Digidesign Hardware & Software | 3 | 06-09-2004 01:56 PM |
Is there any hope. | FatBelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-14-2004 06:44 PM |
IRQ hope? | Taylor1725 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-24-2003 09:17 PM |
There is still Hope | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-15-2003 09:53 AM |
