Old 08-27-2010, 11:49 PM
celadith celadith is offline
Default Will MBox 2 Mini Work...
on my desktop computer? I've been looking at the MBox 2 Mini for ages, but I'm not sure how well it would work on my computer, if at all.
SiSoftware Sandra
Computer
Model : Asus CG5270
Workgroup : WORKGROUP
Host Name : Zeus
User : Miriam
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Speed : 2.5GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Asus CG5270
BIOS : AMI 0302 08/10/2009
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 8GB DIMM DDR2
Chipset
Model : ASUS P45/P43/G45/G43 DRAM Controller
Front Side Bus Speed : 4x 333MHz (1.33GHz)
Memory Bus Speed : 2x 400MHz (800MHz)
Memory Module(s)
Memory Module : Asint BW9J2LF4FN1 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Video System
Video Adapter : NVIDIA GeForce GTS 250 (128 SM4.0 1.7GHz, 1GB DDR3 2x1GHz, PCIe 2.00 x16)
Graphics Processor
Adapter : NVIDIA GeForce GTS 250 (128SP 16C 1.84GHz, 1GB 2x1GHz)
Adapter : NVIDIA GeForce GTS 250 (128SP 1.7GHz, 1005.6MB 2x1GHz)
Storage Devices
Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (C:) (D:)
HL-DT-ST DVDRAM GH40N (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
NKFMN LQV0HQB49 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (F:)
Logical Storage Devices
WIN7 (C:) : 373GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
DATA (D:) : 551GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
Optical Drive (E:) : N/A @ HL-DT-ST DVDRAM GH40N (ATAPI, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (F:) : N/A @ NKFMN LQV0HQB49 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
LPC Legacy Controller 1 : T0 B0-73
Audio Device : ASUS HD Audio Controller
Audio Codec : Realtek Semiconductor High Definition Audio
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : ASUS 4 port SATA IDE Controller
Disk Controller : ASUS 2 port SATA IDE Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller
Wireless Adapter 1 : NETGEAR RangeMax(TM) Wireless USB 2.0 Adapter WPN111 (802.11g (ERP), AES-CCMP, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 08-28-2010, 04:30 AM
Default Re: Will MBox 2 Mini Work...
It looks like it SHOULD work to me, but please get a few more opinions. In any case, you still need a separate recording drive(a partition is NOT a separate recording drive). Assuming this is a desktop computer, you can probably install another hard drive internally, which is the cheapest fix, and gives the best performance. If you can't fit another internal, then be aware that USB drives are NOT supported, firewire drives MUST have an Oxford 9xx chipset, your firewire port MUST use a TI chipset(if you have no port, then a 3rd party card is needed), and eSATA should work fine(if you have an eSATA port).
Old 08-28-2010, 04:00 PM
Hotcrazyfruit Hotcrazyfruit is offline
You have a respectabke quad core, 8 gigs of ram...(more than most users on this forums) Yes. It will work, and quite well once you complete your optimizations
Ps get a WD Caviar Black drive to record to
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Mbox 2 mini will not work on new Mac 10.8.6. PhilT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-04-2013 07:53 AM
Can't Get Mbox Mini To Work With PT LPSlashLP Windows 2 01-07-2013 05:10 PM
Mbox 2 mini will not work fredrickj Windows 4 05-17-2011 03:48 PM
Mbox 2 mini doesn't work sytrusze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 07-13-2010 07:13 AM
My mbox 2 mini no work jonslaten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-04-2009 09:43 AM
