Old 02-15-2010, 04:31 PM
mikemk21 mikemk21 is offline
Default Latency between left to right outputs
I have just started using PT M-Powered 8 with my fast track pro.
There is and acute playback problem - mainly latency between the left and right outpoots. But also dropouts and distorsion too.
What I tryed doing 'till now:
I played around with the playback engine parameters in every possible way.
Tryed changing the USB cable/headphones/and even brought over a similar sound card which still had the same problem.
Any help will be appriciated!
Mike
computer specs:
win XP sp3 32 bit
Mainboard : Gigabyte P55A-UD3
> Chipset : Intel P55
> Processor : Intel Core i5 750 @ 2666 MHz
> Physical Memory : 4096 MB 2 x 2048 DDR3-SDRAM
Old 02-15-2010, 05:47 PM
necjamc necjamc is offline
Default Re: Latency between left to right outputs
How did you test this?
I would like to test it on my own system to see what my results are.
Edit: The Latency between channels, not the distortion or dropouts.
Old 02-15-2010, 06:10 PM
I just tryed working a session on an external USB WD 7200rpm hard drive and it seems to be OK now for the first time. Hopefully this is will solve the problem for good
Old 02-15-2010, 06:35 PM
USB drives are not supported and have been known to cause problems with Pro Tools. Was the latency between channels a lot? Did you do a loop back to check the outputs or were you just hearing latency?
Old 02-15-2010, 09:15 PM
TOM@METRO's Avatar
necjamc is correct, you will most likely get into trouble using a drive with know issues.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-16-2010, 04:36 AM
What drive would you recommended?
Old 02-16-2010, 08:33 AM
Glyph FW drives, You can get them from sweetwater, or Guitar Center. They are pretty much a standard in the industry.
Or if it's a desktop, WD Caviar Black drives are good internal drives, a lot of people use them.
using all analog outputs in low latency stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-20-2010 10:56 AM
latency when using multiple outputs? stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-19-2009 09:01 PM
Digi003 Left/Right Outputs Reversed Podgorny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-01-2008 09:24 AM
Digi003 Left/Right Outputs Reversed Podgorny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-01-2008 09:21 AM
Changing Low Latency outputs morganpage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2008 09:00 AM
