Old 12-31-2012, 08:09 PM
DC-Choppah's Avatar
DC-Choppah DC-Choppah is offline
Default What does the length of a midi cymbal note really do?
I am working with the studio drum kit in the Pro Tools sampler Structure. But I have heard the same effects in other MIDI drum kits.
I sometimes will hear the cymbal crash sort of drop down in volume unnaturally. But I can go in manually and expand the bad crash note to make it a little bit longer and then the crash is smooth with a natural die out.
Just wondering if anyone knows about the guts of the thing, what exactly the length of a MIDI note controls on a crash. I could learn to play it correctly if I understood.
It's not like the crash stops ever at the end of the note. I mean the sound tapers off slowly. But the MIDI note length is doing something.
DC-Choppah's Project Studio:
ASUS PRIME Z390-A / Intel i7 rackmount PC
Windows 10 home 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
Tascam US-16x08 Interface
100% Analog real time monitoring 16x4
Yamaha 16 channel MG16XU Analog Monitor Mixer
Yamaha MX-88 / Novation XiO keyboards
Mackie 4-channel headphone amp
Adam A8X monitors
Blue / Shure, etc. microphones
Estonia 6' 8" Parlor Grand Piano
Yamaha Studio Drum kit
https://www.dc-choppah.com/
Old 01-01-2013, 01:18 AM
Mark Ziebarth Mark Ziebarth is offline
Default Re: What does the length of a midi cymbal note really do?
it depends...on some things. The sample player you use for playing back the drums is responsible for how the MIDI data is interpreted. Drum samples are often played back in a "one shot" called playback mode. That means once triggered by a MIDI note the whole sample will be played back, even if the MIDI note is very short.
If the normal sample playback mode is chosen the length of the MIDI note determines if the whole sample will be played back or if it stops earlier. But a dedicated release time in the samplers envelope settings can undermine what you do with the length of the MIDI note.
So the MIDI data controls only what the playback device allows to control.
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 01-01-2013, 05:03 PM
DC-Choppah's Avatar
OK cool.
I never thought of fiddling with the amplitude envelope for the drum kit, but I see now I can play with the envelope for drums too. Thanks for that.
So I set the enveloped to all 0% in Structure which is now applying no amplitude change to the crash sample. So I guess that means I am just triggering the sample.
It seems that once the crash is about a quarter note long it dies out normally. But less than that and it can have a weird little drop out, sort of like it is ducking.
It seems to me that if you want crashes to sound natural, the note needs to have a certain length, like a quarter note.
Pro-Tools 11.3.1
Adam A8X monitors
Old 01-01-2013, 06:53 PM
DC-Choppah's Avatar
There is apparently more to this.
I just found a spot where the crash cuts out no matter how long I make the note.
But if I start playing from right before the crash then it is fine.
But if I start playing a bar earlier, where there is another crash first, then the crash cuts out early.
I wonder if I am I running out of sound voices or something?
Pro-Tools 11.3.1
Adam A8X monitors
Old 01-01-2013, 07:24 PM
Bill Denton Bill Denton is offline
Just a hint, and I could very well be wrong about this, but IIRC, at the beginning of a MIDI note, the "triggering device" (DAW, sequencer, whatever) sends a "Note ON" message out the specified channel and port, and at the end of the MIDI note, it sends a "Note OFF" message.
Now keep in mind that when the MIDI sequencer sends a "Note OFF", the note produced by the sound source will end. If the audio is being fed to the "BMF Cathedral" preset on a reverb unit, the audio from the reverb unit does not stop with the "Note OFF" message; it will decay normally.
And keep in mind that a processing unit built into your drum virtual instrument may behave differently than a "plugin" processor.
Now, like I said, I may be off on the "Note ON" and "Note OFF" messages, and if I am, somebody please let me know...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 01-01-2013, 10:33 PM
If the problem persists or occurs randomly, I would record the crash cymbal to an audio track and design the ending to my liking.
I don't use Structure too much so I can't help you with any settings there.
Mark
Old 01-02-2013, 08:29 AM
Another possible solution to the crash that cuts out; delete the note from the piano role and drop a new note(also, make sure that note isn't for a choked crash sound). I use Addictive drums and SD2 and every once in a while, a note seems to be corrupt in some odd fashion, Delete and replace usually fixes it, and with these plugins, there are certain notes that yield a choked crash be design
Old 01-02-2013, 06:36 PM
DC-Choppah's Avatar
That was it. But it was not the crash note, instead there was an open high hat on the previous beat that was cutting off unnaturally in the middle of the crash. It's like it was being choked by the crash coming in.
I have note figures out what causes the open high hat to close consistently. If you just hit it once, it rings. But when it rings and you hit certain other notes, it closes.
Pro-Tools 11.3.1
Adam A8X monitors
Old 01-02-2013, 07:22 PM
Can't solve that one, but I can offer a work around; Toss up another stereo instrument track with the same plugin, and put your hat notes on that piano roll.
FWIW, I've not heard this in Addictive drums, ezdrummer or SD2
Old 01-07-2013, 06:03 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Check note velocity of the events that are making it behave this way, some sample patches have different sounds mapped at different velocities.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 07:10 AM
MIDI note length in ticks jteipen Pro Tools 10 1 03-26-2013 09:12 PM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Please help, Midi note length... Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-31-2007 03:59 PM
seperating velocity and note length? is it possible? tritonkorg MIDI 3 04-24-2007 11:09 PM
