Old 04-29-2014, 02:25 AM
Landed87 Landed87 is offline
Default Re: Maverick with Pro Tools LE 8.0.5
Originally Posted by RangioftheLight View Post
I've upgraded my 2008 MacBook Pro to Mavericks and Pro Tools LE 8.0.5 runs fine with an MBox 2 and MBox Micro. Mavericks notified me that Pro Tools is not compatible, and moved the Mbox and Midi plugins to a "Incompatible Software" folder. I re-installed the MBox drivers, and now ProTools runs with no problems at all. Audio and midi record and playback is perfectly fine, plugins work and other sound sources (itunes/quicktime etc) work through the MBox.
Others have not had my good fortune tho it seems.
http://duc.avid.com/showthread.php?t=342256
It seems to be a risky process, so I'd suggest you back up everything before upgrading so if it doesn't work for you you have the option of restoring back to a compatible state.
Hey I have been looking EVERYWHERE (..on the internet) for an answer like this. I'm running LE 8.0.5 with mavericks and my midi has disappeared.. PLEASE tell me what you did to re-install drivers and get it working again!!!!?? Was it from the original PT8 disc??
Would be greatly appreciated as i can't fork out for 11 right now, THANKS!!
- Chris
Old 12-03-2014, 09:18 AM
PSimpso PSimpso is offline
I'm about to install PT LE 8.0.5 on a Mac running Mavericks. Anything I should know before I do it? Has it been working for you all?
It looks like there are only drivers supported up to OS X 10.9.4, should I avoid installing 10.9.5? http://avid.force.com/pkb/articles/e...02-003-Drivers
Digi 003 Rack + and Maverick, HELP! Planet Records Italy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-29-2014 10:04 AM
Maverick & protools 11 mgsr70 Pro Tools 11 7 01-25-2014 05:06 PM
Digidesign Midi IO not working properly in Pro Tools 11.1 HD on Maverick! bigknowsal Pro Tools 11 1 01-05-2014 07:39 AM
Mbox 3 and Maverick Clash Ghetty FireWire & USB Audio Interfaces (Mac) 0 12-31-2013 01:58 AM
Digidesign 002 and OSX Maverick 67Thunderbird Digidesign Hardware & Software 0 11-27-2013 04:58 AM
