Old 01-27-2014, 09:10 AM
pyrodave pyrodave is offline
Default Automation latency when using plugins that have long latency
I have been having issues when using Waves DeBreath plugin.
When using delay compensation in Pro Tools 11 and automating the plugin for example to bypass the plugin. The automation triggers way before it is programmed to.
I have spoken with Waves QA department and they have tested this, and it appears to be an issue with the way Pro-Tools 11 automation reacts to plugins which require long latency correction. This issue was recreated with other plugins that introduce long latency times.
Has anybody else had this issue? Hopefully Avid will fix this in future updates.
My spec;
Pro Tools 11.1.1
OS X 10.9
Waves AXX 9.2
Waves Install V9r15
Old 01-27-2014, 10:13 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Automation latency when using plugins that have long latency
Personally, I would use Waves DeBreath as an AudioSuite plug-in only.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-27-2014, 11:22 AM
Top Jimmy's Avatar
The best you can do at this time is highlight the automation data in the edit window and shift it the number of sample of delay incurred in the plugin.
James Cadwallader
Automation Latency sphereman macOS 3 09-14-2012 06:12 AM
Latency over long distance? Kdawg2087 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-08-2007 06:04 PM
Why is there so much plugin automation latency? Ale Pro Tools TDM Systems (Mac) 2 02-26-2007 08:40 AM
Long latency at 64 samples? Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2006 06:54 AM
Plug-In Latency List...Warning Long Post Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 02-14-2006 11:42 AM
